Feedback To Source
Started by nievesoliveras, December 21, 2008, 11:28:28 AM
nievesoliveras
Quote from: gadgetmall on January 20, 2009, 10:11:41 AM
@jesus
Theres no reason My circuit couldn't work powering your motor and feeding back . If you wind a regular 40 turn Jt  then wind two more secondaries one with 12volts and the other 12volts ,replace the dc converter  and test run the Newman on the Jt output . you will need variable resistor in any circuit you put a load on to tune it for an output .. Have you tried that ? solder some wires on your pot so they can stick in the holes
Thank you!
The problem is that I cant make the circuit to work from the pulse motor coil output. I am making experiments and already I have the photos that I will post tomorrow.
Another thing is that, in order to accomplish my goal, the feedback has to be to the 1.5v battery of the 1.5v to 12v booster circuit.
If I cant feedback to a 1.5v battery, then I have not accomplished my goal.
Jesus
nievesoliveras
@gadgetmall
You are important here too.
The test 4 will be with your toroid recomendation.
Please fill the question marks or write the answers on a post.
Jesus
gadgetmall
Ok let me take a look at that beginning schematic again ... Because the Newman motor is supposed to charge itself . It is Done with two contacts opposites the run contacts. Now i was told the run contact should be as tine as possible just enuff contact to spin then again the contact Just break the pickup contact catches the back spark and feeds it back with a diode to the run battery  much like Bedini circuit . Its the timing of the contacts that make it over unity and run it self . I guess you know that though But i will have another look after My and my little one eat some tomato soup . We have been playing int he snow all morning .. FUN!!
gadgetmall
Ok i just rethought this . What if you take the outputs ? ? and Put a Bridge on it then run it back . you probably all ready tried this with similar results of system stopped working ?  Have you tried this mod to your circuit . Look .
nievesoliveras
@gadgetmall
I tried something similar but the circuit was not the one I have now.
View it here:
http://www.overunity.com/index.php?topic=6362.msg146283#msg146283
As soon as I get the parts from goldmine I will try your suggested configuration. On that order there comes 2 good small bridge rectifiers. They dont take too much space on the breadboard.
Jesus
