Bring Dead Ni-Cad Batteries Back To Life
Started by Magnethos, December 24, 2008, 08:56:13 AM
Magnethos
I also remember that I read in a book
' In other words, here's the iron rule: If you draw current, you kill the bipolarity gate furnishing the potential gradient (source of energy density). In that case, you kill the source. If you do not draw current, you do not kill the bipolarity gate and you do not shut down the source. In that case, you can continue to "use" it and extract trapped EM energy from it forever. '
I also read in other book that the universe works in a principle of neutralization/equilibrium. That means if we draw current from the source, we're turning the asymmetric poles into symmetric poles. The bipolarity gate means the process of trapping energy from the vacuum while the dipole is asymmetric. But if you draw current, there is a process where the asymmetric poles turn in symmetric poles. This is best know as Amperes-Hour. Common physics says that a source is limited by the amperage, but in the reality a source is limited by the time that get to turn from asymmetric poles to symetric poles. When you have a potential difference (asymmtric poles) in a battery, the bipolar gate is open, but when the poles are symmetric, the bipolar gate is closed and the battery doesn't draws power.
So, when we draw current, the universe is neutralizating and putting in equilibrium the poles to 50% each one. 50% and 50% means symmectric poles and also means closed bipolarity gate.
Excelent work!  :D
nueview
Symetrical as same being like or akin to
Asymetrical having a property or not akin to
capacitive charging of a battery as bedini does with caps lets current lead voltage on charging perfect input to the system dc  charging uses voltage and current in phase poor charging heating would be a problem for the most part a capacitor is a battery and vice versa exotic dielectrics and the like lithium alkali and the like even ferile epoxy more here than emediately meets the eye and some fine material think this helps me with my project but not totally sure how just yet it does simplefy some of my problems thuogh with battery charging transisters will be the real problem may have to find some tubes or relays but there so darn slow.
someone here was saying use inductive charging but that doesn't seem right to me now but a capacitive power supply is making a lot more sense it would be a minor change and may be well worth the effort but you would have to loose the reverse pulse as it would be to a detroment and a diode bridge may not work properly just a few thoughts.
time to start christmas hear my grandkids thank you for the christmas present it was the best i've had in many years.
Pirate88179
Quote from: PaulLowrance on December 24, 2008, 01:24:02 PM
I'd agree the battery could be zero volts, but it probably would not stay there for very long. It would probably slowly drift back to it's original polarity.
As you said, PM's can also reverse. I've done that by pressing a Neo and frig PM together where they repel each other. They will repel until the neo gets close enough to the frig PM, and then the frig PM will flip and then they will attract. The neo has high coercivity, and it's strong enough to flip the weak frig PM.
PL
Just for the heck of it, I once took two strong neos and super glued them together while they were repelling each other. (same poles)  I had to use vice grips while the glue was drying.  Once dry, the magnets switched their poles such that the "stack" now had a north and south on the top and bottom.  So, for this to happen, one of them had to flip or something otherwise I would have ended up with 2 norths or two souths. (which I was actually looking to do)  It was interesting.
PaulLowrance
Nice experiment Bill!  How long did it take to flip?  I'm wondering what the actual *flip* time was. Perhaps if you wrapped some wire around it and connected a voltage meter or scope. If it doesn't flip too fast, then you could separate the PM's when they're at zero B-field (degaussed). I'd love to know the change in temperature while the PM goes from magnetized to demagnetized.
PL
Pirate88179
Paul:
I don't know how long it took exactly.  I used super glue and held them together in the vice grips for about 2 minutes.  Once I saw they were going to stay together I immediately tested the poles and basically just ended up with a thicker version of what I had started with. (one pole on top the other on the bottom)  So, good question.  Somewhere in there a change took place.  Was it all at once? (my guess is yes)  It would be interesting to do using a magnetic field indicator. (Like the one that guy made with iron filings suspended in mineral oil in a clear bottle, it shows three dimensional magnetic fields)
Maybe the change happens the instant the two are forced together?  You could put two into a pair of pliers and then test the poles to see.  I never did fool with it much after that as I was looking to create some special magnet with weird poles but.....didn't work.  I still have it glued together here somewhere.
