Tesla's Flying Machine
Started by jandell254, December 27, 2008, 08:50:05 AM
v71
one motor with a shaft where 2 counter rotating motors spun a large inertia momentum discs
i tried to make them rotate counter wise to each other, make them rotate in the same direction both counter and clock wise, modified the attack angle  same, 180, 90, 45 to each other.
No way you can trick the angular momentum conservation.
Sorry for my english though
web
mmm...Are we talking about the same setup here - the one shown on message 1 of this topic ?  You mention large rotating discs but theres no rotating discs in the alleged tesla diagram
v71
I used large rotating disc because or grater intertia momentum, small bearings like tesla 's machine cannot produce trust in any direction.
My machine was a proof of concept , but i can be wrong of course,
web
its not clear from your description where you're using discs but if you're using them instead of the rotating unbalanced masses as described in the diagram, then there would be no unbalanced forces and the whole thing would simply have balanced spinning discs with no unbalanced force to possibly be able to move in any direction.  I was just trying to follow the logic of the original diagram.
web
I just came back across this site again and just wondered if anyone else had an opinion on my previous posts on a possible way to make the device work ?
