Capacitive Power saver , C.P.S
Started by gigawattgratis, December 31, 2008, 11:56:15 PM
Creativity
second try this time with calorimeter.
I put like 1 ml of water in the small container together with digital thermometer probe and 38 Ohm resistor.This all went into the thermos.
2 caps of 1miliF each and voltage from power supply 9 V.
I let the temperature to stabilise,after 15 min i got 13,1degC.
I zapped the resistor with C1 but unfortunately no temperature gain.
I will have to choose higher voltage caps and lower resistance i guess.What do u all think?
PS: i checked the setup if it is working with 1s of direct current 9V.Temperature has risen and stabilised to 13,8 degC after 15 min.
Blues it through your outstanding life,leaving more than just footsteps behind (1999 B-stok by me).
By being intensively responsive to what others say,i do run a risk: I open myself up to the opinions of others.i will,at times, have a great understanding for their opinion.Sometimes,i will even change my own opinion because i realize that the other person is right.This "risk" i do not run if i am unresponsive to what others say.
gyulasun
Yes, it sounds better to vary the resistor values and the voltage level.  You have had a time constant in the some tens millisecond range  if I calculate correctly and this may be very quick and would need a fast response and higher resolution thermometer.
Creativity
in calorimeter the time of discharge has no importance,just the total energy supplied.I let it for 15 min to stabilise the temperature over the whole volume of liquid.
To invest in more accurate thermometer is pricy way to go.
Instead of water I will try methanol or ethanol as it has much lower heat capacity(order of magnitude)+ i will use less liquid so it should be easier to see any changes in temp even with lower discharge energies.
BTW: i dont really see where the extra energy should come from in this setup.i thought that maybe original experiment was done wrong by letting the cap to partially recharge from the falling wheight.
wizkycho
...it is not just time to meassure here but when using motor it is allso - speed, when using diode - current through it
when connecting motor to fully charged C1 (and C1 only) motor will all the time run faster (higher overal voltage)
then when C1 is "poured" through motor to C2...
I'm just saying that one should not oversimplify this. Would be nice to see actual test of lifting weight but when it is done it allso
needs to be taken in account not only height but allso time to lift weight on certain height. - cause at different speeds (RPMs) of motor
different are losses or gains...
I would love to see test simmilar to test that genesis (motor with PermMagnets) conducted.
motor has constant 300rpms speed and lifts 4 times larger weight(with PM) at same height then without PM.
that would be proof...
Wiz
Creativity
Quote from: wizkycho on January 22, 2009, 10:24:19 AM
Wiz
time is playing its role in power(how fast something happened).Work done (energy) is not time dependent(how high wheight got lifted,what the end temperature was etc.).But sure it would be nice not to sacrifice power in this setup.If u have a link then post it please.
