Natures Perpetual Wheel
Started by FreeEnergy, December 15, 2005, 05:43:23 AM
lltfdaniel1
BUT THEN AGAIN If the top ball aint in time then the whole SYSTEM , IT Can't work, by the looks this guy has it right.
its like that Clutch system (in a nother forum) ;-) .
useing the Brake i mean.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
lltfdaniel1
This Design could actually be modified in a way that it wouldnt need the brake,
for instance the traveling distance of the ball,
it would needs to be changed in a way like that it would be in SYNC even if the process SLOWED Down (due to load resistance)and then i would say this would really be a self Maintaining Gravity Motor and i do actually think this design has it, (although it needs the brake to stay in Sync) it should HAVE AN Automatic system which would sort that out,
FOR INSTANCE A SEMI-AUTOMATIC Gear box like on a motor bike , when you press your foot on it , it automaticly does the rest, so this does have the potental to be a self sustaining gravity motor,
its just the Traveling distance of the Balls........ if only it was instant like when it drops out it Almost immedatly gets picked up , then that would sort the BRAKE PROBLEM OUT.
if the cups don't get in the way then i see it can.
lltfdaniel1
the cups should have a Flap mechanism.
unless there is a way to speed the balls fall..............(A Spring like that in a ping pong board ;-)? )
or somewhat rotated in a way,
what i am on about is if the balls speed is lower then lets Say <10ms then ether if its 1ms or 9 ms it would still be able to fit in the right pully (due to the balls size ;-)  )
and it would still be okay to run.
or 50ms.. would be alright .
(to stay in sync when the motor is changeing speed, ;-), but if at a stable speed then this really aint to much of a problem,if your not going to use a BRAKE..)
lltfdaniel1
a possible solution to the cup problem, the left and right pullys must not be Parelle.
now i see it..
like that in a pingpong board.
http://img236.imageshack.us/img236/7725/idea9se.jpg
lltfdaniel1
a lower Ms on a internet connection is better than a higher ping , other wise your going to get LAG Spikes . and more problems .with sync issues.
