Problems with TPU building and Free energy devices in general.
Started by ben8807, January 08, 2009, 10:58:48 PM
nkovchak
macidonia, a question to you related to EV kick.....
...is it possible to shield the magnetic field by pulsing collector?
nk
MACEDONIA CD
nickc
my long explane  has simple
and short explane
LIKE  THIS
IF YOU MAKE   PRYMARY COIL  WHIT LETS SAY  WHIT 200  TO  CORE LIKE THIS  FOR 50 HZ   THAT  COR E  WHILL NOT TRANSPORT  WHELL GOOD   THAT FREKH  AN DTHEN YOU AUTOMATICLY DONT HAVE GOOD TRANSPORT PARTS AND NOTHING
AND IF YOU MAKE PULS FRE  SQURE
THAT IS NOT FREKEFENCY
THAT IS  DC CUT IN PIECES  PULSES S NOT FREKFENCY
IF YOU TAKE  5 VOLTS PULSES FOR FERITH CORE   AND MAKE  TURNS  <<YOU MAST KNOW HOW MUCSH YOU WHILL MAKES TURNS OF NUMBERE
BUT THERE IS WRONG IF PULSE <FREKFENCY IS  50KHZ  YOU WHILL MAKE  HMMM MORE TURNS  AND THAT COIL WHILL BE  TUNE  TO 5 VOLTAGE YOU MAST CALCULATED  YOUR COIL  LIKE YOU PUT ONE HZ  <50KHZ AND 10KHZ AND ATHER PULSE FREK IS  ALLWAYS  THE <,ONE HZ  <<AND TAKE  THIS  AND ALLWAYS CALCULATED  LIKE YOU HAVE  ONE HZ
AND THEN THE NUMBER  OF TURNS FOR ONE VOLT WHILL BE   FOR EVERY FREK <,ONLY FOR PULSE
IFYOU MAKE  5 VOLTS  FOR SINUS  FOR 50HZ  THEN YOU TAKE CALCULATED    WHIT <45>AND IF YOU MAKE 25 HZ SINUS YOU TAKE <<22,5 >.
IF YOU MAKE 12,25HZ SINUS  YOU TAKE   11,25   AND  IF YOU GOING TO  ONE HZ
AND ONE HZ IS PULSE    THEYOU WHILL TAKE  1 HZ   = 0,98
AND THEN YOUR NUMBER  FOR  PULSE FREK WHILL BE ALLWAYS  TAKE THIS CALCULATED WHIT <0,98
LIE THIS   YOU HAVE  TRASFORMER WHIT  <<a and b side  <<squre   dimension
and is like this
a*b = ?
and  then 0,98 / ?  =  of how many turns for one volts  for  pulse squre
and
but if you put sinus more then 50hz  then  calculation  whil increasing the numbes per turns
like this if you put  100 hz sinus
<50hz is ... 45  >>
<100hz is ... 90>>
<200hz is ..  180>>
and lie this  <<a *b side of core =?
and    <<45 / a*b =  how many turns for  one volts for 50hz
and for 100zhz is
<<   90 / a*b = how many turns for one volts  for 100 hz
and you see  that is simple  if you INCREASING THE SPEED OF ELKTROMAGNET FILD    WHIT TUNE CALCULATION YOU WHILL HAVE SOMETHING
IST  OR NOT  ;)
MACEDONIA CD
EVERYTHING     <,TUNE >> CLOUSE THE   STATION TRANSMITER ;)
nkovchak
So....? macedonia,
we deal with dynamic superconductivity of collector  ring and directional pulse what moving around without losses with superposition at standing wave. Each turn compressed the pulse to indefinitely ( in general), so we able to reach boundary E/H/B effect. At this critical point an energy transformer doesn’t  seems working properly in meaning of adding extra power to output to reach overunity?
nick.
MACEDONIA CD
