Fusionchip's Bedini Feedback to Source!!!
Started by Goat, January 09, 2009, 11:54:12 AM
plengo
@gadgetmall,
Thank you my friend. Today I got the SK3606, they are a beauty. I immediately removed my diodes and replaced with the SKs. Right out of the batch I notice the perfomance is totally changed. I can run this with the fan very slow and I even think the sound is the same as you have. It runs with a strange fluctuation of 2ma to 10ma per turn. Battery voltage did not even blink from the resting voltage.
Definitely those diodes make a difference. Hopefully I will be able t tune it to the point of not only keeping the voltage stable but also going up. Lets see.
@all
Today before leaving to work, I replaced my transistor NPN-3904 with a TIP32A and tried different quick configurations. Before I did that voltage of the battery was about 0.01v down again but as soon I left the system disconnected while I changed the parts the battery came back to the same voltage of 4 days ago.
I tried a few tunnings and had to leave to work and asked my wife to keep an eye on the fan to see if it would run away too fast or stop. Later she called, about 3 hours later, and said the fan had stopped. So quickly I figure the pot resistance setting was too high, so I asked her to turn the nob. Oh boy, what a mistake. When I came back home from work the fan was simply running too fast and drained the battery about 0.02v above the normal 0.01v totaling a 0.03v down.  :( :( :(
BUT, i got the new parts from gadgetmall and disconnected everything. Guess what? battery in 5 minutes was back to the same voltage again and I put it to run with the new SK diodes. Voltage has not dropped even a tinny little bit with those guys!!!!!! AMAZING.
Off course now that I am here I tuned to my best and it was easy to tune it too.  Another thing different with the SK's and the new transistor is that the voltage on the CAP (which I had to install back) rises very, very fast to 100+volts, may be 20 seconds it will be there, which before with the other diodes and the PNP3904 was not happening that fast.
Fausto.
plengo
Quote from: AbbaRue on February 17, 2009, 05:29:25 PM
@plengo
I bought a 48 volt fan today that looks almost identical to yours,  same company even.
But when I opened it up it doesn't have bifilar windings in it, only a single strand from coil to coil.
How do I modify this type of motor?  Did yours have bifilar windings?
Should I modify it like nievesoliveras shows in his diagram a few posts up?
So 2 of the 4 windings are power and the other 2 are the output pulse?
It would be a lot of work to rewind this with a bifilar coil but I may have to do that.
If so I would just leave the circuit board intact and just remove these windings and rewind with bifilar.
If you look very close, very, very close with a magnifying glass you will notice that ONE of the coils is a bifilar. Those wires are less than a hair tick. Impossible to see by naked eye.
Concerning the configuration I would assume that nievesoliveras is correct but I can not confirm yet because I did not touch none of the widdings neither would advice you to. Look closely you will see that in one of the 3 posts one has 2 fine wires into it. Melt the lead and separate the two wires. Each will now be a new post or connection to the external circuit, totaling 4 wires in the end. That's all I did.
Look at the videos from Fusionchip. That's actually what I did before doing this 48v fan. I did not even put a post there, I just used tick wires to connect directly to the enameled wire of the fan and firmly glued the tick wires into the base of the fan, leaving enough space for the rotor to run without friction.
I will try tonight dismantle another 48v fan and take many pictures with close-ups so that everyone can see how it is.
Fausto.
Fausto.
plengo
Quote from: Goat on February 17, 2009, 07:13:13 PM
@ All
I also bought a 48 volt fan today but it's only a 2 pole bifilar (see pic), anyone know if and how to go about wiring this fan?  The last 48 v fan I had was wrecked when I brought it to a shop to press out the shaft  ::)
Regards,
Paul
Oh boy what a nice widdings. Goat I think you are in trouble with this one here. What I can advice is, see if you can somehow find 4 wires ends on those metal posts. Measure the resistance in all sort of combinations and see if you can infer which one is which. I kind of did that on my fan and I noticed that two widdings are really one, as Fusionchip is saying.
From those two widdings you will have 2 posts and the other 2 widdings would be another 2 posts (or wire ends) and one widding will be infinite resistance to the other widdings, forcing you to see that they are really two sets of two widdings in the motor.
In nievesoliveras picture is what we see logically but I dont think it is really that simple. The SSG motor needs only two widdings really, one is the trigger and the other is the power (as nievesoliveras  shows) but with this fans they are somehow organized in two sets of trigger and two sets of power coils. Makes any sense?
Fausto.
hartiberlin
All,
many thanks for the recent information
on the Fans.
I also bought one 12 Volts fan today, but did notyethave time to
open it up.
Is there any circuit diagram out there on the web  for these 48 Volts fans ?
I just want to see, how they are normally wired in their normal coil configuration.
Do they use one of the parallel wound bifilar coils for controlling the speed or triggering ,
or why do they use these parallel wound bifilar coils ?
gadgetmall
Quote from: AbbaRue on February 17, 2009, 07:39:00 PM
@gadgetmall
I already built a bedini from a 12 V computer fan so I know how to do it now.
But this 48 V motor I bought is wired different it definitely has only one strand going from coil to coil.
Also one end goes to a pin but the other end goes directly into the circuit board.
Totally different setup from the 12V computer motor I modified.
Anyone else buying these motors should try peeking into the crack of the motor to make sure it is bifilar wound.
Because some of them are wound with only one strand.
@gadgetmall did any of your 12 volt versions clearly show more output then input?
Mine definitely runs the battery down as it runs.
I tweeked the pot. for hours trying different settings and always seen the battery voltage keep  going down.
I bought a few larger 12V fans to try building another one, maybe a larger fan will put out more power.
I looked through the crack in the rotor of them and can see they have bifilar windings on them.
Princess auto only carries the one type of 48 volt  fan and  it's not bifilar wound.
Well i didn't want to say anything about another one that selfruns BUT yes the first one i did in the video with the caps on the input with a 9 volt battery will run itself .thats all it does it dost drop and it dosnt gain . it was a 12 volt fan . Its resistance was the highest of 8 12volt  fans i modded . 91 ohms per coil.. . No i am not kidding . the other fans had around 30 to 40 ohms resistance and shorted out when i tried all of them . Weird ? I gave it away for Christmas . You have got to get some of these 48 volt fans shipped to you the link is a few pages back . they were only 1.79 each .i bet everybody and there father has bought all of them . I got 20 comming and i will probably sell My Completed units including the battery for around 1000.00  or you can make it but you wont get the diodes . i sold 16 of them in like 3 days on the net and i have about 20 more and i am using them in the completed units .. Fasto got the last one :)
Ps Can you Snap a Picture Of the Stator you have in question and post it here . ?
