Fusionchip's Bedini Feedback to Source!!!
Started by Goat, January 09, 2009, 11:54:12 AM
Goat
@ gadgetmall
I appreciate your help.
You sounded a little frustrated in your last post, please don't be, just don't answer me if somehow I get your blood pressure going...
I understand what you're saying it's just that the 48 Volt rotor has a steel post and is an aluminum frame bottom and the rotor won't break away from it!
I've watched both yours and Imhoteps videos and I've had the same results as you for the plastic fans where I ended up gluing everything back as you did....but this one's different.
Because of the steel post on the 48 Volt fan the stator is not budging short of taking a hammer to it!  I've already pried on the stator short of damaging it (I hope I didn't) but so far the easiest method still looks like punching out the shaft to get at the stator.
I know that my model number is slightly different than yours because of the speed control, maybe it's construction is different (the picture was posted above).  The picture here is of the bottom where you can see the stator shaft and how it's pressed in.
Regards,
Paul
gadgetmall
Im sorry i looked back at my post and yea My Bp was up . You have a unique fan . I have never seen one with an a cast frame . Interesting . Mine had a speed sensor on it also. three wires red black and white.. well shoot . i would try just heating up the back a little and see if the glue comes loose if there is any and i suspect there is . maybe a hair dryer on the back for a while then get a rag and see if it will come loose if not i guess the only way is to beat it up or  dremal it out . if you had a hole saw that might work ???as i said you can order these fans now there is another place  i posted you can get them like i got .Another thing is i want to help yall . i had a few bad comments on the powersupply bedin saying it was a scam and some how i faked the video . that pissed me off . then there was another guy that told me DMM dont measure right with High frequency . I know that but its  filtered DC going to the battery no pulses and then he said the lead acid battery was somehow heating up creating the illusion of charging up when it was really discharging . What a Crock , I am Redoing the experiment with nicads or a gel cell and redoing the video. the problem is it only gives me 10 mins on utube and there is not much i can show cause the voltage goes up slowly , just slightly over unity and if i do it in time lapst then there goes the door open for more criticisms  . you know i am proud of what i did and i don't really care anymore if someone don't believe me or it . at least i am happy with My inventions and they do what i want them to do for ME.. .  G nite bud ..
Hoppy
Quote from: gadgetmall on January 25, 2009, 02:41:11 AM
Hi Gadgetmail
The way to prove that your setup works OU or near to it is to reduce the size of your battery down to say 2.8A/hr and then monitor the discharge voltage. I too get a rise but it does eventually fall. Its to do with battery internal resistance alterations. A big battery will show a slow rise of terminal voltage over a considerable period of time.
It does not really matter whether people believe or disbelieve you, whats important is not to delude yourself.
Hoppy
AhuraMazda
It is easy to prove if your system is OU in a short time. Use a large capacitor, charge it up and instead of a battery, use the capacitor.
gadgetmall
@hoppy . ok i am doing that i have one of the smallest 12 1.2 amp hr batterys they make  . it is brand new . i will build one more cause i have more fans an parts  and test that theory . also i have some little nicads . it will run on 6 volts also i will try it that way too.
@AhuraMazd
Been down that road . it blows transistors . it need a buffer ,the battery . Voltage is way too high as you see in the video it put out over 100 volts in less than 1 min thus a Big bang . that will just blow the circuit .
