Fusionchip's Bedini Feedback to Source!!!
Started by Goat, January 09, 2009, 11:54:12 AM
gadgetmall
Quote from: comwarrior on May 25, 2009, 12:56:36 PM
Thanks bill,
TBH, the only reason for me posting here is because fusionchips feedback to source is still going after i blew it out of the water...
And since that i've now managed to do it, i thaught i'd save people the brain-ach...
I am working on an impressive mod to the entire bedini system based uppon the use of opto-couplers... Wasn't originally going to do it, however, my line of developement is about recovering and generating power to make a bedini self power...
As an spin off, my use of the feedback to source causes my drive pulse to be stronger due to the slightly higher voltage pulse... The weird thing is, my use of the back emf apears to effect the amount of power produced by my recovery coil... so anoying when i discover yet another 'power see-saw'...
Anyways, enough for now... I've extensively documented everything i've been doing on utube... about 3 hours of video i think...
Excuse me ? you Replicated it and failed is what you did . Mine is still running .If you Blew me out of the water then why are you feeding back ? I don't lie and i don't appreciate FOOLISH remarks basically calling me a liar . I am not . You failed . i didn't . When you can run your bedini on one milliamp like we can come back other wise go bark up another tree .Have a look at jonnybravo's bedini.
Gadget aka fusionchip
gadgetmall
Quote from: comwarrior on June 22, 2009, 05:07:08 AM
Actially, TBH, the only technical guys i'm in contact with on a regular basis are drevtoobe and pwordcharnoir... Other that those two i got about 5 begginners on my msn list that i'm helping out when they need it...
i guess i annoyed a few people...
Probably because you dont know what your talking about and Claim the Concept as your own when it was mine . a while back when i built the fan bedini feed back system .you said it couldn't be done . and John Bedini as well told us the Sg was designed to "SHUT DOWN" when attempting to feed back the output . I did it and proved that it can be done . Me not you . And several Replicators here have done it as well with the right part . I stand behind My Claim that i discovered a way to feedback the secondary  with a standard bedini with a few modifications . And i posted it open source FIRST period. So anything having to do with My circuit Concept is My intellectual property and proven to work . The only thing  not proven is more out than in and only a few have done it .myself included . I need not prove it to anyone other than myself. I am true to Myself and know what my eyes see . there are hidden factors which i cannot describe be it parts, or placement of parts , resonance in length of wires and other factors of components but i can say that one of my 48 volts fans runs itself and charges as well . I won't post here unless i find another interesting way of feedback to source from a bedini or bedini like circuit .In my opinion 5 seconds dont  count .Days might .month yes . years of running a self runner is a problem without special switching and discharging of a selfrunner  OU Bedini . The Batterys will Cook and dry up yet they are the most important part of any bedini .
GADGETMALL
aka FUSIONCHIP .
guruji
Quote from: gadgetmall on June 22, 2009, 09:21:11 PM
Its My battery swapper . replace  in 220k ohms with a pot to engage the SMALL RELAY to switch battery's for a Perpetual Jt . It simply triggers a relay when a set voltage is reached therefor swapping two battery's once one is charged . Its application can also be used for a bedini if you replace the relay (s)
Gadget
Hi Gadgetmall thanks for response so that part on the right is a relay. Can you please tell me what type of relay is that? Is there a part number?
Yes I need it for my Bedini charger.
Thanks
gadgetmall
Quote from: guruji on June 23, 2009, 02:40:55 PM
Thanks
This system was designed for a Jt and the circuit is being powered with 5 volts . I made this for a Joule thief battery swapper . as you know a joule thief is just like a bedini circuit wise . the relay is a small 5 volt 1 amp relay available from goldmine electronics . i don't have the part number handy but any 5 volt relay will do / for a bedini the 5 volt relay should then switch another relay with its own coil voltage and power supply to handle the amperage in a bedini battery . ie 12Volts .
Gadget
llewgnal
Boy this Kontara CRAP is a bunch of Garbage, very annoying...
  GET RID OF IT! >:(
