Building a UFO
Started by Halifax, January 17, 2009, 03:29:22 AM
Steven Dufresne
@Hal,
If you're going to go with an SEG, keep in mind that the parts needed may be simpler than what Searle says they have to be (i.e. may not need all the layers.) See the Roschin & Godin replication:
http://www.rexresearch.com/roschin/roschin.htm
-Steve
http://rimstar.org   http://wsminfo.org
He who smiles at lofty schemes, stems the tied of broken dreams. - Roger Hodgson
Halifax
Freezer - I've been over every bit of available information on the web for the OTC-X1 and related craft. There is not enough information to build it. I even went so far as to try and email Ralph Ring. Alas, to no avail. It remains simply one more unsupported story.
Steven - Thanks for that link! More than a bit of useful information there!
Z - Thank you for that! I have always enjoyed Schauberger's work. This will be most enjoyable. As for the rest of it, if you feel so inclined: use your disgression and the following two rules: does it work (has it been replicated by someone else?) and is there enough information to replicate it?
-Hal
Halifax
There are a couple of critical pieces missing with the SEG that put it in the almost unbuildable catagory. One is the lack of an explanation of the Law of Squares and how it relates directly to the amount of materials used (the Roschin and Godin experiment may make this a moot point), two is the fabrication of the required magnetic elements (specifically the stator) - though I will be putting in for a quote with a company to see what the costs might be (the specifications of the material quote will be for the Roschin and Godin work).
Beyond that I really don't see any limitations. The arguement that the Roschin-Godin work is somehow invalid at this point does not concern me.
I will continue to dig around for more info on the SEG. It seems to me that a solid state circuit of some kind could operate in the same way as the SEG. At this point in time, however, I have no idea at all.
Thanks for all the info so far!
-Hal
spacetrax
Maybe you should take a look at those UFOs which make a tornado underneath, by exhausting hot gases under pressure through a ring shaped exhaust. The hot gas tornado is said to create a very strong magnetic field and antigravity. Good luck!
Halifax
Quote from: spacetrax on January 18, 2009, 12:33:52 AM
;) See this link for more information on these particular drive types. I do like Schauberger's work even if it isn't solid state electronics.
I considered these for a short while, and I may do something with them.
-Hal
