Thanks to ALL for your help!!
Peltier Question: size and rating
Started by charmrus, January 17, 2009, 05:51:15 PM
charmrus
Im looking to purchase some Peltier juntions for power generation experiments and am a bit confused by what I should get.  They are listed by thier wattage and size.  The wattage thats listed is for what it consumes for use as a cooling device.  Im seeing wattage differences for same sized package also.
Basically what Im in need of is how would I figure which or what  attribute I should be using for comparision for getting the most bang for the buck.  Would 2 30mm pcs be better then 1 60mm pc.  Is there a "potential" density to the different sizes/wattage?
I realize that the temp. difference from one side to the other makes a difference but how would I compute that into wattage/size?
Thank you for any help given.
sushimoto
DAMIT DAS MOEGLICHE ENTSTEHT, MUSS IMMER WIEDER DAS UNMOEGLICHE VERSUCHT WERDEN.
crazyoldfart
I have several different values, 80 watt , 120 watt and 250 watt , all with voltages around 18 volts for maximum and 4, 6 and 8 amp respectively. they all need a temperature differential of 100 degrees to reach 2/3 rds their rated value. 100 degrees differential is pretty hard to achieve in everyday life. but you can drive a couple of high intensity LED's with a difference of only 40 degrees or so. with  a single 80 watt device and a temperature differential of 40 degrees , I was able to get around 5 volts @ almost 2 amps without voltage drop. On a much larger scale this could work very well, in my opinion.
