Pyramid found at "Fort Carson" US Millitary Facility
Started by fuzzytomcat, January 21, 2009, 06:14:06 PM
fuzzytomcat
Here is what I've came up with on the "Tropical Year Frequency" Circular Arcs I'm looking "Down" on the North pole with the Earth is running CCW with three hundred and sixty (360) CW magnetic flux circular lines penetrating the Earth three hundred and sixty times (360) places around the "Equator" each "Circular Arc" in sets of three (3) phases A, B, and C offset one (1) degree in sets of three (3). There are one hundred and twenty (120) sets for each of the three (3) phases A, B, and C. This is a change as you will see to finalize this theory of "Teslas" wireless transmission. ( everything in multiples of three )
The "Tropical Year Frequency" Circular Arcs .....with quantity of arks in a multiple of three to cover exactly all existing explained and unexplained areas of interest with large grounding rings or pyramids around the world either ancient or new ran by government agency's.
There are one hundred and twenty (120) sets of three (3) circular arcs for each phase or 120 degrees, the three circular arcs per set are connected in a "delta" or "star" more commonly known as a "Y" configuration A-B, B-C, and C-A inside the earth. The one hundred and twenty (120) Y connected sets of three (3) circular arcs are totally separate being one degree (1) apart for a total of three hundred and sixty (360) degrees (Tesla Poly). This would verify 100% of what Tesla said that was possible to send radio waves, electricity, video or photos and energy waves and more as there are one hundred and twenty (120) Y connected sets of three (3) circular arcs to work with as long as you have a "EARTH" ground to gain access on land with each of the one hundred and twenty (120) per phase Y connected sets of circular arcs.
As far as I can determine there are only five (5) sets being used as follows -
The first "Omega" ground reference building at -
( 00 28' 02.50"S, 90 17' 01.71"W )
W 30 degrees 30' Phase A center of circle
E 90 degrees 30' Phase B center of circle
W 150 degrees 30' Phase C center of circle
The second set ties together is "Wardencleffe" Laboratory facility in New York, Camp Upton "Brookhaven National Laboratory the Pyramids in "Gazi" lower Chile and Argentina and Thunguska -
W 24 degrees 00' Phase A center of circle
E 94 degrees 00' Phase B center of circle
W 144 degrees 00' Phase C center of circle
The third set ties Teslas sites in Colorado Springs, Peterson AFB, Fort Carson and protected Pyramid complexes on base -
W 35 degrees 00' Phase A center of circle
E 85 degrees 00' Phase B center of circle
W 155 degrees 00' Phase C center of circle
The forth set is used by "Cern" in Switzerland and France -
( 46 14' 05.59"N, 06 02' 34.98"E )
W 38 degrees 00' Phase A center of circle
E 88 degrees 00' Phase B center of circle
W 158 degrees 00' Phase C center of circle
The Fifth set is used by "Area" 51
( 37 14' 6"N, 115 48' 40"W )
W 37 degrees 00' Phase A center of circle
E 97 degrees 00' Phase B center of circle
W 167 degrees 00' Phase C center of circle
As far as I can tell "Area 51" is separate similar to the "Cern" set.
Earth
44,075.02 Km  cir.
"Arks"
13358.34 Km  dia.
6679.17 Km radius
Ark radius at "Equator" points 10 to 15 "Miles" wide ( 5 x 5 ) depending on moon and tidal effects.
addtional information, photos and illustrations see -
http://www.energeticforum.com/renewable-energy/showthread.php?t=3573   Tesla's wireless electricity transmission
Fuzzy
mindsweeper
I drove by there today, IT'S A LAND FILL SITE. Honest. Perhaps the secret site is under all that topsoil but I assure you. It's land fill.
fuzzytomcat
Quote from: mindsweeper on January 24, 2009, 05:04:52 PM
Mindsweeper,
The access road into the pyramid complex is on a rise and 500' to 800" away is at 5644 feet the pyramids are much lower at all the tops or any thing there in the complex.
The main secured road at the "Tee" intersection is at 5584 feet at a locked gate .81 miles on the only road into the complex past the locked gate .68 miles the road rises to 5644 feet, the pyramids are .13 miles past the high spot on the only road in at 5543 feet 103 feet below the ridge into the pyramid complex. How did you see over the hill ridge into the complex its over 100 feet below the main road behind locked gates ??
As far as I am concerned now you are with the government or a agent and doing nothing but giving out disinformation that has been going on now for years, you have no expertise in this area and have not spent countless hours going over every inch of the 2000 acre's surrounding this area using "Google Earth", other satellite imaging maps, USGS Topographical maps and several other Map references to come up with this information ...... not a drive by ..... that you can't see jack .....
BEP
I wish you success at what ever you are trying to accomplish but such threads as this make me want to ask.....
Who are you working for?
Just in case you are what I think you are please include this in your weekly report:
You have succeeded in washing out virtually all of the publicly posted research on the site. However, all of that research continues using other communication methods.
Oh! And sign the quote as 'In God We Trust - All Others We Monitor'. That should wake a few of them up  ;D
fuzzytomcat
Quote from: BEP on January 24, 2009, 09:50:11 PM
Hi BEP
Right this minute I work for the people the common person to make things right and hopefully to stop world suffering, I have never worked as a government "employee" in any shape or form, I'm just a plain "Electrical Contractor" with a "Electrical Engineering" background.
It's also to vindicate one of the greatest inventors of our time "Tesla" he deserves better than what has been given him by the media and the government, dyeing a poor man for what he has accomplished, not to benefit just the military of countries and a few select private government ran laboratory's. I also think that just like anything else using frequency's for TV or Radio that some of these arks can be designated for public "Wireless" use, using some kind of guide lines that can be agreed upon by public and government elected groups.
I could have held this back for fear of what could or may happen to me or my family, I chose to tell the world and believe me I did, and just not a few threads on a couple of forums. If I make anything monetary from this it would be from lectures from this information and possibly some others I have obtained if it's unclassified, right now I've not disclosed because of "real" possible security issues that may be connected.
Fuzzy
