Youtube video of gravity device principle.. ?
Started by hartiberlin, January 21, 2009, 08:54:10 PM
hartiberlin
Hi,
if anybody understands the basic operation of this device,
please let me know and post some more explanations.
http://de.youtube.com/watch?v=pXatO92If-I
How can he move the water the distance 2X with less work with
multiple containers ?
Many thanks.
Regards, Stefan.
Mr.Entropy
It doesn't take any work to empty and refill a container, as long as you use the energy that you take out when emptying it to refill it again.
The easiest way I can think of is a spare container connected by a siphon tube, and held up by a counterweight via a cam-shaped pully that keeps it balanced at every height.  Then you can move the spare container slowly up or down with essentially no work, and the main container is filled or emptied via the siphon tube.
The trouble with this free energy idea lies elsewhere -- the "output unit" must be heavy enough to stay underwater as the tank is emptied, but buoyant enough to flip around an axle and lift the heavy internal weight.  You can't have both.
GavinPalmer1984
Quote from: Mr.Entropy on January 21, 2009, 11:14:56 PM
The "output unit" must simply float at the surface of the water.  When the water level lowers, the output unit will fall below the uni-directional latch.  When the water refills, the output unit will seek to float at the surface and can be flipped with minimal energy.
For the mass of the output unit = m; Volume of the entire output unit = v; And density of the water = p;
m < vp
Problems arise when the temperature changes... density changes.  Thus the mass and volume should be designed in a way that will allow a "window" of temperature changes.  The window is very small if the device runs underground.  And when the device runs underground, the output wind can be used to regulate the temperature of a building (geothermal) & provide electricity via a wind turbine.
If the output unit is slightly above the surface of the liquid, the dimensions of the outer tank and the amount of water emptied will be adjusted so that the top axle of the output unit will fall below the uni-directional latch.
pese
Another YOUTUBE Free Energy movie
(Compressor water drive turbine -- that drive an electric generator.
last power the pump again, additional LAMPS !!
MUST SEE ! (and reconstruct it ?)
http://de.youtube.com/watch?v=0p3kkaDlWx4&feature=channel
Gustav Pese
ramset
Mr Palmer
Thankyou for sharing this concept [which I am presently studying [Your video]
Mr Pese
That fellows video has/is being discussed in this forum [some feel cavitation is playing a part]
I will find the link and post it
Chet
Thanks Grandma
