DEK motor with U-coreless coil or Lenz boxing against Lentz
Started by woopy, February 02, 2009, 03:31:57 PM
woopy
@Jadaro2006 and Broli
yes simply typo   excuse me :-\
@Nievesliveras
thank' for interest and proposition     can you be more precise about the components value  of your circuit ?
@Yucca
very nice job congratulation    wayting for the next results
i like the proposal of using one leg of the UCC as motor and the the second one shorted as BEMF recup or generating "à la Thane"
i have recieved my oscilloscope yesterday and i begin to get used with it    it is surely also THE instrument to investigate how it works
@all
I like very much what is going on with this thread  i learn a lot  on a quite new matter for me   every day         and only for that it is worth
my supposition on  " Lenz boxing  against himself"  is not verified at all untill now  with the UCC   on the contrary it seems to be "Lenz pushing himself"
i have made some test with pendulum magnets traveling through shorted UCC     and the UCC clearly damps the pendulum movement       so the BEMF seems to be  always there :-[
anyway lets go on :)
btw  i have got my copy of  "Peter Lindemann    Electric motor secret    DVD"  and i wondered if it was possible to decrease the  so called "efficiency masking BEMF effect"  by using a long distance between the legs of the UCC  so to say to get   "long  middle torquy stroke pulse "     and not      "short explosive pulse"  ??
cheers
Laurent
nievesoliveras
Quote from: Yucca on February 14, 2009, 11:47:53 AM
Hi, Thanks Jesus,
The brown board is a cheapo prototyping board as you probably know, I presume you're asking about the blue board: It's a freeduino microcontroller board. You buy them cheaply and you get free programming tools for windows. You just need a USB cable like a printer cable, nothing else to buy. Stacked on top is a nokia LCD screen, again cheaply available.
You program it up using C language.  I will be developing the pulsemotor program so that the user can specify all aspects of timing in tenths of degrees, so 3600 steps per revolution accuracy.
I chose this route because I thought when you're hunting for magnetic anomolies it's good to have reproducible conditions for different coil and mag setups and also good to have an accurate RPM meter. When I evaluate the running I ignore the current draw of the controller unit which is about 110ma at 9V. I just look at the current draw of the coil driver circuit (on the brown board). I'm hoping I might be able to make this current be negative with much more experimenting using Thanes (@crankypants) Perepetia effect.
If you or anyone else wanted to get a controller unit and you dont know C language (yet) then I could give you the pulse motor program via PM and then you just need to click your mouse to program it up. It's a very handy system for researching pulse motors of different configurations.
you can buy the controller and screen board from a UK company here, they have fast and reasonable international shipping:
micro board:
http://www.nuelectronics.com/estore/index.php?main_page=product_info&cPath=1&products_id=1&zenid=4acea1063d04071e9cf1c8785ccdf53f
screen board:
http://www.nuelectronics.com/estore/index.php?main_page=product_info&cPath=1&products_id=10
Yucca.
Thanks @yucca
This is the moment to buy those electronic boards, but at the moment my budget does not allow me to buy them.
Maybe I will regret not have buyed the boards. But I cant  spend money. I am unemployed now.
Another thing is that the price is displayed in other country currency, maybe in dollars is three times the amount.
Thank you anyway.
Jesus
Yucca
Quote from: woopy on February 14, 2009, 05:32:10 PM
Laurent, be very careful when scoping pulsed coils with your scope. It is easy to damage an oscilloscope, I once learnt the hard way. I always use a 100x probe when going near pulse motors with my scope.
Yucca
Quote from: nievesoliveras on February 14, 2009, 05:33:00 PM
Thanks @yucca
Thank you anyway.
Jesus
That´s a shame, the currency is UK pound which is very low at the moment. I´m sure the arduino and freeduino boards will be around for a long time yet so you could get one in the future maybe.
You may still find it useful to put a LED in circuit that lights when the coil is on, this allows you to see where the coil fires relative to the magnet and is great for getting a "feel" for coil mag setups. It´s good to see where the pulse is when you´ve tuned for optimum.
All the best, Yucca.
nievesoliveras
@Nievesliveras
cheers
Laurent
Forgive me I did not see this question before.
The answer is here:
The resistance can be from 10 ohms to 680 ohms. I usually use 100 ohms and works well.
The transistor could be any NPN. I ususally use 2N2222A.
The diode could be even an LED with the cathode to the base. I usually use 1N4001.
@yucca
I will get some money and buy the freeduino board with the other one, I forgot its name now, soon.
Jesus
