Real OU-Effect to Share with everyone!!!
Started by Magnethos, February 02, 2009, 08:37:03 PM
Frederic2k1
QuoteExplain me more about that, because that extremely fast switching time it's difficult to replicate by me.
You need a cascade-amplifier to generate high-voltage potential and store this in one or more caps. Then you need a spark gap, where the distance between each contact can be adjusted with a screw. Above and under the gap is in each case a perment magnet or an electro magnet, it will "blow" out the spark when it discharges.
That is the principle behind the magnetically quenched spark gap, the level of voltage and the distance will define the frequency, the magnetic flux of pm or e-magnet will define the shortness of the spark (time-duration)
QuoteI don't know how to calculate the relaxation time using variables as the high-inductive coils. I only know to calculate the relaxation time in pure metals.
I also don't know how to calculate it. I think there is need for experimenting, because there are doubtless some more factors involved.
Magnethos
Frederik,
QuoteIn the other threads of the TPU-subforum I often hear the people crying for very fast switching and I think that this is the key to overunity.
And we need nothing more than a spark-gap, then you have your very fast switch. Also in many Tesla-patents he used his spark-gap and you can control the frequenz of switching by changing the capacitance of your condenser or the distance between the gap.
My question is... How can I change the Frequency and what is the maximum frequency that I can achieve? Using the spark-gap
You have just said that the distance between spark-gaps and the voltage can adjust the frequency. Any formula? Or I need to experiment?
The important question is... Can I achieve a frequency of 10 ^ -14 secs ? (100,000,000,000,000 Hz)
Frederic2k1
Why do you need such a frequency ? Use high-inductive coils and there will be no need to achive frequencies in this dimension.
Tesla was not only able to charge capacitors with this sudden disruptive discharge, he tried to collect the aetheric scalar waves with a device, described in Patent # 685,958 "Method of Utilizing Radiant Energy."
With this device he was able to collect the radient waves from the aether (the cold-electricity which he created) and convert it to conventional electrical current.
Will you see this method on a real free energy device ? Then look at this: http://www.youtube.com/watch?v=1rFjrPo9mws
Magnethos
QuoteWhy do you need such a frequency ? Use high-inductive coils and there will be no need to achive frequencies in this dimension.
I think I need to use that frequency because if I use a lower freq, then the current saturates the circuit and I would be drawing current from the battery. But using the high-inductive coil... as you say, the relaxation time changes... but how much? we don't know...
So... if you say that using high-inductive coils, I don't need to use that high frequency... Can I extract pure potential from the source? I know there is a lot of theory in the net, but I haven't seen a succesfull replication yet.
Frederic2k1
@ magnethos
sorry, you don't understand me right.
Haven't you seen a "Current / Voltage" graph of a high-inductive coil?
First there is voltage, and then later comes the current. So every high-inductive coil is in fact a device to increase the saturation-time...
As I mentioned before, NRG were never be able to achieve overunity when he hasn't that high-inductive coil. With it, the relaxation-time increases to a range, where he can switch per hand...
Did you ever read the book "Free Energy secrets of cold electricity" ?
