Real OU-Effect to Share with everyone!!!
Started by Magnethos, February 02, 2009, 08:37:03 PM
robbie47
I've been reading this thread with great interest.
I am an electric engineer myself and have many years of research experience at the largest science laboratory of Europe. So it's hard to take some distance towards the traditional theories that mostly are used. Nevertheless, I think that experiments that challenge traditional insights, like this one, are necessary to make scientific progress.
I have a basic remark to NRG:
The principle you show is more convincing when you use two identical capacitors.
(one charged, as power source, one to be charged)
Would it be possible for you to perform your basic setup with 2 similar capacitors?
Zigis
Today i made few tests.
Because I haven't wire and all other parts for good coil right now, and because I am impatient, I take choke from old tube radio PS, unknown inductance, 43 ohm resistance and 30 mf x 400V paper in oil.
From source 12V car battery I can get 35-40V in best trying, with 4 small 9V batterys in series (30V) I can get 80-87V.
I see, timing for best result is very difficult. My best results was with 2 test probes from multimeter on cooper PCB's cut-off.
I am not trying calculate efficiency, because my coil is far from required :) I just want to see how this effect work, and what timing is required.
With hand hit it is hard to understand, why sometime is good result, sometime no.
Then i try to use DP momentary toggle switch, double pole relay. In both I can't get good results, I get only 2-3V on few seconds, and than voltage disappears. I try to change relay's contacts place with no results.
I think i can get very short contact time, there is no problem. My guess is - with perfect synchronic switches it not work, small timing is needed.
Next week I am going to try build good coil for future tests.
Zigis.
PaulLowrance
Zigis,
You only need the right kind of relay. Using the plate method the person can get quick & far gap distances. Most relays have short gap distances. Also the relay should have a strong spring, otherwise it's too slow.
PL
Zigis
Thanks Paul Lowrance,
about slow reaction and springs I am thinking too, do you think distance between contacts in open position is important too ?
Maybe I can find in flea market some old large power relays and take contact group from them.
Zigis.
gotoluc
Quote from: NRGFromTheVacuum on March 08, 2009, 01:08:54 AM
Hi Luc,
Without getting into details, your capacitors voltage values are incorrect.
You did a great job building the circuit from the looks of the video, but the results are poor for the following reasons:
For the source capacitor you need a lower voltage value with high Farads. <-------(This caps written voltage value must always be lower then your collector caps)
For your collector capacitor you need a higher voltage value with low Farads <-------(This caps written voltage value must always be higher then your source caps)
Keep building, the best results will come in due time. I found so far that brass is the best metal to make & break the connections on, copper is only second best.
Thanks for the reply NRGFromTheVacuum,
I have a 30 volt DC 30,000uf cap that I'm quite sure I had also tried as supply cap with the 400 volts AC 60uf motor run cap as receiver but don't remember seeing a better result.
I'll give it one more try and if I get a better result I'll post a new video.
This could be a very specific combination of coil and cap size and you are closer then me with it.
Luc
