Magnetic Rotation in the Rodin Coil - was the Bell really a myth after all?
Started by magpie, February 04, 2009, 10:59:48 PM
PYRODIN123321
Mercury and fluoride are both dangerous in large quantities. you shouldn't handle it, you should not have mercury amalgam fillings either, they emit mercury vapor in the presence of moisture
i didn't have a choice but, I wouldn't have gotten the mercury/thymarisol vaccine, I have looked at the actual mercury content in the shots its very very low but, for example, what if there were trace bits of shit in your food, I don't want shit in my food-even if its just a tiny tiny little bit of shit you'd never notice....same goes for mercury....
In 1939 a dentist named H. Trendley Dean, working for the U.S. Public Health Service, examined water from 345 communities inTexas. Dean determined that high concentrations of fluoride in the water in these areas corresponded to a high incidence of mottled teeth. This explained why dentists in the area found mottled teeth in so many of their patients. Dean also claimed that there was a lower incidence of dental cavities in communities having about 1 ppm fluoride in the water supply. Among the native residents of these areas about 10 percent developed the very mildest forms of mottled enamel ("dental fluorosis"), which Dean and others described as "beautiful white teeth."
Dean's report led to the initiation of artificial fluoridation of drinking water at 1part-per-million (ppm) in order to supply the "optimal dose" of 1mg fluoride per day--assuming that drinking four glasses of water every day would duplicate Dean's "optimal" intake for most people. Now, according to the American Dental Association, all people, rich or poor, could have "beautiful white teeth" and be free of caries at the same time. After all, the benefits of water fluoridation had been documented "beyond any doubt."13
When other scientists investigated Dean's data, they did not reach the same conclusions. In fact, Dean had engaged in "selective use of data," using findings from 21 cities that supported his case while completely disregarding data from 272 other locations that did not show a correlation.14 In court cases Dean was forced to admit under oath that his data were invalid.15 In 1957 he had to admit at AMA hearings that even waters containing a mere 0.1ppm (0.1 mg/l) could cause dental fluorosis, the first visible sign of fluoride overdose.16 Moreover, there is not one single double-blind study to indicate that fluoridation is effective in reducing cavities.17
Ingesting fluoride can cause flourosis that turns your bones brittle, for teeth its ok on the outside because it causes a little crystallization and protects them but ingesting it causes a lot and not just in your teeth, also i have read that both mercury and fluoride can have mental effects, mercury reduces I.Q. and fluoride i think makes people more docile and does other stuff I'm sure...
I know also that sodium flouride is a byproduct of uranium enrichment, and i remember reading an article about how it got into the water supply by accident....
here's a article on fluoride
http://www.consumerhealth.org/articles/display.cfm?ID=19990817225011
and here's a (propaganda) article refuting most of that one, says fluoride is naturally occurring in water and sodium fluoride is just helping nature along....right, and helping nature could never go wrong right... lol
http://www.quackwatch.com/03HealthPromotion/fluoride.html
There are people who constantly believe only the things they want to, and disregard facts. we all do this to some degree but.....
Personally I think you would be best to avoid, and how much do you trust what one person says as opposed to another anyways, is it worth getting cancer or something because of what somebody says is not dangerous?
do your research and remember people do stupid things all the time, but that does not mean you should too...
Peace.
gravityblock
I agree that both mercury and fluoride are very dangerous.  I just have a hard time understanding how mercury can be OK to be used in the vaccinations, when it is not OK to have mercury thermostats or is too dangerous to experiment with.
The amount of mercury in the vaccines may be small, but the effect is additive from many different shots during a person's lifetime.
Taking the flu shot 3 out of 5 consecutive years will increase your risk of Alzheimers disease by more than 1000%.  My grandfather had a stroke 2 days after taking a flu shot.
The mercury in the vaccines is causing autism, diabetes, asthma, etc.
This is not rocket science to know it is causing harm, even in small doses......but it is OK to be used in the vaccinations and nothing else. LOL
Dave45
what does the dangers of fluoride and mercury have to do with the roden coil.
good grief
science not paranoia, be cautious but quit freeken
gravityblock
Quote from: Dave45 on June 16, 2009, 06:47:59 PM
good grief
Mercury was mentioned earlier in the thread for an experiment with the Rodin Coil, and was said to be too dangerous to experiment with. So I mentioned, why be worried about the experiments with mercury, when you will more than likely go get a vaccination with mercury in it, or have in the past.  Just trying to point out how peoples reasoning is not right, and should not be a factor in not experimenting with something that may have a great benefit.
Of course we should be cautious with our environment, weather it is exploding capacitors, high voltage and current, magnets flying off the rotor at high speeds, or with the dangers of mercury.  Thanks for the tip.
Any one of us could be killed in a car accident tomorrow, so does this mean we never travel by car again cause of the potential dangers?  Of course not. There are dangers all around us.  It's the same with mercury.  Since when did this ever stop us from doing something that is necessary, beneficial, or convenient.
I will do the experiments if someone gives me the Rodin Coils, the magnets, and the mercury.  I will take every precaution to protect myself from harm as I normally do with the other things.
Nobody is paranoid or freakin. LOL
MasterPlaster
The people who are talking about the dangers of mercury etc in this thread are clearly trying to derail the thread.
