Electromechanical Inverter
Started by z.monkey, February 05, 2009, 05:55:55 AM
pese
second movie
THE  ring-bell,
reference circuit as shown 0:27 in movie.
this output cant so read !
the output have speakes of some hundreds volts,
that voltages are so short (milliseconds" tat you must normally
not die!
you will become an "SHOCK" if your fingers will
touch both ends of the breaker.
only if you charge up an condensor (exp: 1mf 1000Volt
polyester or paper-film via an fast recovery diode than you ca read
the peak values of the voltages  otherwise you can see tat on osz-scope.
Tis is only an back-EMK that can be find in any choke, transfo and any
other induction coils.
0:47
this 4,5volts are never dangerous.
you can test, if the battery is god or not with your thong !
that induction voltages is the only "shocking NEW" if first connessance.
1:45
Aaha he ave found his "somehundred volts " if he use the rigt diode he can also charge higher voltages.
BUT is not power behind ! NO Overunity, nothing : ONLY "Losses"
I play this if i was 7 with my father (EE).
THIS IS THE WRONG WAY for Free Energy.
Schoolar Physic, not more
Te first video with his 140volt . NO VALUE this circuit also IF 100 or 200 milliwatt
are "lightning".
YOU "lightning head" have discover that this total power, adsitional losses vomes ONLY from the battery
G.Pese
pese
Quote from: z.monkey on February 05, 2009, 06:25:29 AM
Look at the configuration of the relay.  It's a Inverter...
Here's a better picture...
very old circuit.
all car radios 1936 to 1950 workes tis way..
that was the simplest way to receive the anode voltages
(approx 150volts FOR TE "Vacuum-reicever Tubes. that was
need for any radio receiver.
Simple from line voltages 117/230 volts. BUT tho have ths
from 6 or 12 volt car batteries IT NEED this way.
special self resonces relais (named: vibrator)
i tink that workes at 110/120 Herts wir own mechaninacal
controlled resonance frequency
G.Pese
z.monkey
Quote from: pese on February 07, 2009, 02:27:08 PM
very old circuit.
Hey Pese,
I'm going retro-techo, well except for the processor...
I am working my way backwards in time technologically.
This is to fully understand electrical systems fundamentally.
I'm going back to pick up all the little details, all the most
basic fundamental details.
I would like to build a tube amplifier also...
Tito, thanks for the videos, VERY Interesting...
OK, Mo Later...
Goodwill to All, for All is One!
Tito L. Oracion
Hi everyone
Actually i have made a hundreds of volts without using batery but im using the batery! yeah rigth im using it but im not using it ???
without killing the dipole!
bearden tech!
otits
