ENERGY AMPLIFICATION
0 Members and 106 Guests are viewing this topic.
ramset
TEETS
Are you going to tell us a bed time story??
A nice one ??
HHHMMMM?
Chet
Thanks Grandma
Tito L. Oracion
Quote from: ramset on October 09, 2011, 10:18:32 PM
TEETS
A nice one ??
HHHMMMM?
Chet
No! its a WET time story  :D
before achieving overnudity, you chet ready your tongue like this  :P  before doing this  :-* hmmmmmm   and you will feel  :o after that.  :D
oopsss chet! your getting wet!!!!  >:(
:D
:D
:D
forest
Here is your overunity: http://www.w8ji.com/vswr_reactive_power.htm
Apply reactive power to real power lenzless transformer like Thane kind or others.
Tito L. Oracion
Quote from: forest on October 10, 2011, 02:59:02 AM
Yes!, but don't forget also the doping and series parallel technique to add up extra strength ok?  ;)
and always use diode to make electron flow in one way to  avoid fast discharge.  ;)
Qwert
In the book i've recently introduced at reply #1541 of this thread, I've found an explanation of a fact that not everybody is aware of and which for some potential inventors can be an inspiration for experiments. It's in section titled "Stepped-up high voltage from not so high turns ratio" on page 105 (118 of 187):
An experimenter is interested in determining the approximate turns ratio
of an automobile ignition coil. He impresses a small audio frequency sine
wave on the primary terminals and uses an oscilloscope to measure the
induced voltage in the secondary. As a result of this measurement technique,
it is found that the voltage step-up is approximately 100. This does
not appear reasonable because 100 times the 12 V of the automobile battery
falls far short of the 15 000-30 000 V needed for firing spark plugs. What is
the nature of the discrepancy?
Although not commonly referred to as a 'flyback' transformer, the ignition
coil develops its high secondary voltage in a similar manner to the flyback
transformer in a television set. In both instances, the primary winding
requires a waveform with a very high rate of voltage or current change.
Such a waveform induces a high voltage counter EMF in the primary and
it is this induced voltage which is stepped-up further in the secondary. Thus
in an automobile ignition system, the abrupt cut-off of the applied 12 V induces a counter EMF in the primary with a peak amplitude of about 250-
300 V. When this purposely-produced 'transient' is multiplied by a 100 to 1
step-up turns ratio, one obtains the 25 kVor so needed for reliable firing of
the plugs.
