ENERGY AMPLIFICATION
0 Members and 128 Guests are viewing this topic.
ramset
Thanks Grandma
Magluvin
I did a screen capture of the circuit  in case someone does not wish to run the sim prog.
Magluvin
here is updated code to show power out on 1 of the load resistors. They all receive the same voltage/current.
If you place the mouse pointer over the scope shots, the component for that shot will show blue in color. The last  on to the far right is the watts of just 1 load resistor.
Mags
Magluvin
in the above schematic   the switch at the top of the resistor load array will disconnect the load resistors to the left.
Notice the change in power on the resistors that are still connected, not much change at all.  This would be due to the diodes regulating the voltage to the load while allowing  the oscillations to continue at the highe voltages. So the diodes help us skim off 7v to the load on each half cycle. At 400kv That will take a while to degrade, depending on freq.
If you change the value of the 100nf cap down to say 500pf, note the change in running voltage of the oscillator and the time it takes to run down. But take note of the load consumption also. The load needs to be different now.
Tesla And Tito said, a tiny cap can produce a lot of power, well I think this is what they mean.
Add more resistors, more power will come out with little change to the others, to a point.    Add more diodes in series to get higher voltages to the load, but the oscillations will diminish faster, and the loads will need to be different  in ohm value to put out similar power levels or more.
Remove the diodes or just add in switches to disconnect them and check out the output now. This setup alone can produce tons of heat on the cheep.
Mags
forest
please please please
can you make video explaining what to do to obtain results ? in simulation of course but I think we would like to see it happen and how to do this.
can somebody help ? there should be free programs allwoing to make video of it
