ENERGY AMPLIFICATION
0 Members and 186 Guests are viewing this topic.
Magluvin
I copied this from the locked thread. Titos last post there.
"ok.
Everyone lets study the bridge rectifier, is it not that a bridge rectifier can accept ac that is two different direction electricity combining them into
one?, and with the help of a cap, the point of cut is being filled.  ;)  did you get what i mean a say?  :)
hmmmmmmmmmmmmmmmmmmmmm. ;)       ::)
I think that's enough already. many can smell it.  ;D "
And if we read the post above mine here from Tito....  Secret transformer...
We have seen just about every type and style transformer imaginable. Yet there is at least 1 that we apparently havnt seen. According to Tito. ;)
Today, again while at work, thinking of things other than work... ;) I thought, why would Tito say to look into bridge rectifiers?  Well, I looked into it, in my mind. ;D Visions of rectifiers danced in my head.
One of the strangest uses that I recall was the use of only 3 legs in a supposed self running pulse motor. I think it was that crazy guy that hasnt been around for a long while now. IST? Cant remember. He talked all silly like his vids were made after a long bong session.  ;)
I never tried that circuit. maybe there is something to it.
Ok, so we have a bridge rectifier.  All day I couldnt see a way around using them as they were intended.
Then I remembered, the 'transformer', and thought about what could be different.
So I thought about the AV plug for some odd reason. It should be considered a full wave rectifier also, when charging a cap from a 1 legged secondary.
So what if we have 2 secondaries?  We take 1 leg of 1 secondary and an opposing leg of the other secondary. We connect these to the AC input of the bridge rectifier, leaving the unconnected legs of the 2 secondary windings, well, unconnected. Insulate them for now.
I have a few vids on the av plugs on YT. If we attach just say an ant or a length of wire , or even ground it, to the open end of my 1 legged secondary, the cap charges faster.
Open ended, the circuit that drives the hv transformer(in the vids) used about 45ma idle and not much more when drawing from it through the AV plug to charge the cap, 1 legged from the secondary.
But, there is also a faster charge to the cap through the AV plug if we bring a ground wire, ant or just some wire(ant too), close to the capacitor being charged.
If we have 2 open ended secondaries, the 1 leg of the first secondary pumping out while the other is pulling in, we will be charging both sides of the cap at the same time, unlike the AV plug, pumping and pulling one side of the cap at a time.
We will also gain the faster charge, most likely much better than an AV plug with an ant near the cap, because just the fact that both sides of the cap are active, our ant near the cap is built in.  ;)
Just posting the idea. Gunna see what I got to make a 2 secondary transformer and give it a go.  Oh, one more thing, while thinking about the 2 secondaries. They will be capacitively coupled.  Capacitively?  ;)   Well, you know what I mean. That capacitance is the loop closer of the circuit. So with 2 open ended secondaries, we should get quite a bit more output than ever seen from just an AV plug setup.
Here is a vid showing what a little bit of capacitance with an AV pug circuit can do for getting the cap charged quicker. So the capacitance of the 2 secondaries should definitely improve the output in the idea I propose here.
http://www.youtube.com/watch?v=TR3WmK3qrws
Ats all I got.  ;D So far.  ;)
Ok, back to my mind. :o ;D
Mags
Magluvin
It might give another advantage. It might allow the primary to resonate without killing it. ;]
Mags
forest
Quote from: Magluvin on December 28, 2012, 11:08:49 PM
Mags
Correct answer, this is what I'm looking for also. OU coes from LC resonance and secondary not disturbing it. Strangely enough secondary makes OWN copy of energy, no matter what "experts" are saying  :P
Magluvin
Quote from: forest on December 29, 2012, 07:49:50 AM
Hey Forest
It 'might' allow the primary to resonate. ;)
In my AV plug experiments, the more fiddling with antenna on the open end of the secondary, or just laying my hand on the case of the ignition coil, the output increased but so did the input. With those experiments, the increase in output was apparent but unmeasured. I would have to measure the spark. lol  But it does have less affect on the primary than loaded as intended with a neon tube. Those sparks in my video in my last post, with only 1 watt of input , is plenty to ignite a combustion engine. But they use a lot more power in the vehicle to get that spark.  So there might be some savings with this.
Been thinking all day as to this transformer design. I dont even know if it will give OU. And Tito wont stop me if im wrong.  ::) ;D But Im gunna give it a go anyways.
What im thinking is maybe not to wind the secondaries bifilar, but separate layers, due to possible insulation breakdown between the windings. If I do alternating layers, with an insulation layer between(teflon is highly rated. teflon tape) secondary layers, there will still be a capacitance between windings. Think of the 2 secondaries in series with a cap in between, right in the transformer.
Then I was thinking I should make 3 optional transformers. 1) bifi secondaries, just in case. ;) 2) with layers of secondary, wound in the same directions. And the 3rd with layers of opposing windings. Just to cover all bases.
The difference with the opposing windings will be how the capacitive charge between the layers will be dispersed across the winding layers. There may be an operational difference.
The primary will be just a simple push pull center tapped primary, typically used car audio amp power supplies and small neon transformer drivers.
Finally, my first go will be a straight, open core. Then a closed core if I think it might help later.
Mags
Tito L. Oracion
Hi everyone happy new year  ;D
i want these images here for these helps me discover the secret. ;)
The secret is here, the amazing one connection only is the missing part. believe me.
http://images.search.yahoo.com/search/images;_ylt=A2KJkey9D9xQv10A2F2jzbkF;_ylu=X3oDMTBxbGdlMTFzBHNlYwNmcC1hdHRyaWIEc2xrA3ZpZXdtb3Jl?p=free+energy
Always review them and study.  :)
