ENERGY AMPLIFICATION
Vito PL
@All
Happy New Year 2013 .
Tito This  is so simple that you can  laugh?
Vito.
Bob Smith
Mags, good luck with your research. You're a trooper!
I've gone back to basics, reviewing old posts for clues. I do believe what Tito says, that it's a very simple circuit. Here are some of the clues from past posts I'd like to bring up again:
QuoteTito L. Oracion: Page 2  Reply #16 on: April 01, 2009, 09:59:21 AM
@room
Yes i will sir, i'm not just satisfied with the power i am getting, i am currently workin on it, ...I have success about the Tom bearden's degenerated conductor
I believe Bearden's explanation of "degenerate semiconductor" is vital to understanding what Tito's doing. Here's a good doc that explains what the ds is  http://api.ning.com/files/tADqqsjh6wKpg5lZtbxUT1kVI1IhxSokkRmy*bDud30IahCIguG3jA9iROY2sxNiH5N-XR-AuOvqzcF8OFgqx1KHedYWhpOt/TheFinalSecretOfFreeEnergy.pdf
Start reading at page six, and pay close attention to page 16.
QuoteTito L. Oracion: Page 2  Reply #22 on: August 28, 2009, 05:02:55 AM
A tip to all of you: study the real process or the real thing that is happening when charging many caps of at least 10K uf in high voltage dc and discharging it sequencially in a coil with secondary! the only secret here is how you connect the caps from battery and coil efficiently! thats it you have it.
offcourse you pulse it!
QuoteTito L. Oracion: Page 3  Reply #34 on: August 29, 2009, 12:31:54 AM
Quote from: stprue on August 28, 2009, 02:57:00 PM
Are you charging them all at the same time and then using something along the lines of a led chaser circuit for discharging?  ...and probably some back into the coil and some caps for useable energy?[/i]
well, partly you are correct but there is still missing, the technique of using other coil making a kick without using any current from the input and that makes excess or unlimited energy. and i got this technique in henderson file. [hendershot? file[/i]][/font][/size]
my device is a combination of tom bearden, henderson and bedini.
QuoteTito L. Oracion: Page 3  Reply #39 on: August 30, 2009, 12:26:30 AM
hi mark
...CAPACITOR IS THE SOLUTION!!!
QuoteTito L. Oracion: Page 4  Reply #52 on: September 17, 2009, 04:30:23 AM
i focused my self on energy amplification because i believe that the real secret of our previous scientist and inventors is on how to amplify a small energy. tesla, moray, habbard, hendershot, bearden, bedini.
like for example the tesla's radiant energy that was not patented without something in it ok its not weak, WE CAN AMPLIFY IT OK.
The secret is boldly discussed in this forum already its so very easy you have to notice it.
A COIL THAT MAKES A BIG KICK WITHOUT USING ANY CURRENT!
AND WE CAN MAKE UNLIMITTED NUMBERS OF THEM OK
QuoteTito L. Oracion: Page 4 Reply #53 on: September 17, 2009, 04:47:05 AM
Quote from: stprue on September 11, 2009, 02:29:37 PM
@Tito
- What is the physical size of your device?  Can you give us some dimensions? Parts?
- Are you only using 2-3 coils?
- How are they wound?
- How are you driving it?
ARE YOU ONLY USING 2-3 COILS? : its up to your design, the manyer the coil, the bigger capacity you can produced ok.
HOW ARE THEY WOUND? : opcourse bifillar is still the best plus the magic coil that makes the big kick just include it in the bifillar to fill the collector fully charge in energy ok.
HOW ARE YOU DRIVING IT?: well, just a matter of on and off ok. thats how simple it is.
i think you can ask sir otto for parts and dimensions ok. its not a big deal in my device ok its just so very simple device.
Quoteby the way i'm not using spark gap better to use diode and capacitor and magnet ok.
not only one high self inductance but many , you can connect them in series or parallel ok. it depends to you.
note: the used energy should not be returning to the source in order not to kill the dipole ok.
and the used energy can be used also as an output!
plus the real output so you get the used energy and the output energy be added then you get excess then make some little charging action to make battery always alive ok.
I have to go digest this myself. I hope this helps.
Bob
Bob Smith
Thanks for the FE images, Teets.
I like this one:
http://www.next.gr/uploads/135-d0025406e5.jpg
All I see missing are coils.
Bob
