ENERGY AMPLIFICATION
0 Members and 76 Guests are viewing this topic.
totoalas
wireless reed switch spark gap by k1zm  yt
using one end connected to alum pan
this may be used   tito said he used ordinary relay
totoalas
Jes ascanius radiant collector post no 20 energetic forum vy ascanius himself
Circuit on patrick kelly book
Guruji has succeess charging a motorbike battery  post 83
Beside tate circuit  we can explore this also
The coil on the wall by tesla   similarities
Totoalas ;) :D
totoalas
Hv dc spark gap charger 2 130126  yt  imtotob
The 12 v dc relay showed a clean spark  unlike the reed swith which has fast reaction with radiant energy
This can be passed to an ignition coil or crt coil then to a 12 v battery
The fly swatter used 5 v rechargeable battery
If we can change the circuit to 12 v will be better
Bob Smith
Thinking out loud:
Remember the TMT-
Pulsed primary
Resonant coil
Secondary
Suppose we were to take a JT or smiliar pulsed coil arrangement.
- The JT pulses a primary.
- We then wrap a second coil, identical to the one we would ordinarily draw from, but
   shorted, onto the toroid (as resonant coil).  Remember the Larskro video, a shorted coil
   would increase the voltage and frequency: http://www.youtube.com/watch?v=NFowJ-SqEi8
- Then, we wrap a series-wound bifilar secondary over this resonant coil or beside it.
   Because it is series-wound, we have cancellation of magnetic fields, and no secondary
   reflection losses.
Happy Sunday everybody.
Bob
one_christian_warrior
I think that I have discovered an energy multiplier
how is that for energy amplification?
http://free-energy.yolasite.com/
ATTENTION all of you back yard mechanics,,,  [/font][/size] I did an experiment where I let my electric wheelchair act as a free energy device where I gained the power to go an additional 20 feet up a pretty steep hill each time I travel up the hill at maximum speed, (10th gear) and then back down the hill at a slow speed, (1st gear) I repeated this test 3 time, gaining a total of 60 feet before stopping the test Then I repeated the test a few days later, gaining the same 60 feet This was proof to me, that we have discovered a way of gaining free energy   Free energy device found = it is any electric wheelchair I also made drawings of how to build a stand-alone mechanism That I believe should be a way of gaining free energy power supplies On this website: http://free-energy.yolasite.com/ if this site does not allow URLs then  search for "free-energy" and "yolasite"   Please note = to convert a wheelchair into a free energy machine you must first program the settings on the power chair so that your motors run at highest efficiency for this use, (motor+generator) you must make sure that you have highest torque settings = 1st gear as well as the highest speed settings = 10th gear so that your chair works most like the ten speed bicycle in the Vision that our Father was so Gracious to share with me of first going up hill in 10th gear, and then back down in 1st gear   The slower that you travel down the hill The more power that you gain every trip If you traveled super slow, as in inches per second You might end up over charging your battery   PLEASE  BE CAREFUL   I figure that if you keep adding output generators to the belt then you would eventually generate enough power to make up for the power that you are putting into the drive motor   as well as any losses due to friction  until you add enough output generators  to have not only a self powered machine but you can get an excess of power as an output = free energy   If you travel uphill at maximum speed, (10th gear) And then back down the hill at a slow speed, (1st gear) I can gain the additional power to travel up the steep hill an extra 20 feet  Each time you repeat the test of going up and down the hill   I hope and believe that my drawing is a correct representation  Of a stand alone free energy machine for our power hungry world But even if it is not, that just means that we will have to dig deeper Into finding out how my electric chair can be used as a free energy generator   The slower the speed that you travel down the hill The more power that you gain every trip If you traveled super slow, breaking hard continuously  Moving extremely slow, as in inches per second You might end up over charging your battery   SO PLEASE BE CAREFUL   I found a lot of people just pass it off as a by-product of over charging  or heat changes to the battery, and it was just shortening the life of a battery But I don't accept this, as I believe that I could go on forever,(excluding wear + tear)  Your are multiplying the energy by using pulleys  To multiply the rotations of the motors and generators Through simple geometry you are multiplying rotations And with electricity, rotations mean AC electricity   So, you are in effect, multiplying electricity Where you get the initial electricity to multiply By simply turning the large pulley by hand   I hope that others will repeat my test, (with any chair set at max speed + max torque) To prove that this is truly a free energy device Just think about the massive increase in rotations And it seems obvious to me, that this increase in rotations  Means you are multiplying an increase of electricity   It could be a way of paying off our dept By converting everything to free energy Like taking the gasoline motors out of our automobiles for a start    Which would not only increase jobs in our economies but It would also mean that we no longer need to buy so much oil Then we could use the usual money for buying this oil And putting it on paying off the dept   The massive multiplication of rotations is where we can gain the energy. The idea is to put power into the torque of rotating the large pulley of the DC drive motor, which is converted into massive amounts of rotations of the output generators, as we can connect tens if not hundreds of output generators through simply increasing the size of the belt that drives them to accommodate the increase in the number of small pulleys. The vast amount of multiplications of rotations gives you enough power to not only power itself, but cover any loss due to friction, and actually generate an excess of energy. The idea is, to use simple geometry(size change of diameters) to create an increase of rotations through massive circumferential differences. In effect, you are    We don't need the air polluting effects of the combustion engine any more We have self-generating electricity generators That can be made to practically any size or voltage So that we have the choice to have almost everything self powered   I know this will work, and I believe that this will change the world that we live in for the better. I proved that the idea works with my electric wheelchair experiment, but I have not been able to get a bicycle light generator to finish the prototype.(something I will be struggling to remedy for a while now) I also thought of using an electronics simulation software to not only prove that it works, but then we would have a video of how one actually works. I know, it`s so simple it seems too simple to work, and if it would work, then why wouldn't someone have thought it up earlier.   I know, it`s so simple it seems too stupid to work, and if it would work, then why wouldn't someone have thought it up earlier.   I figure that if you keep adding output generators to the belt  then you would eventually generate enough power to make up for the power that you are putting into the drive motor   as well as any losses due to friction  until you add enough output generators  to have not only have a self powered machine but you can get an excess of power as an output = free energy output generator               Here are a few of the reasons for this system to work miraclesThe massive circumferential differences between a large drive pulley + tiny generator pulley
You put power into turning a motor only once-(lg) When the power out generator(s) spin hundreds of times faster Each rotation gives you power to put back into the system
Then you could add tens of these output generators
All of these would be turning the many hundreds of times faster  Them you could enlarge the drive motor pulley to the max As well as shrinking the size of the pulleys on the output generators
To maximise the multiplication factor even more So lets see, you are putting energy into the high torque motor with a large pulley And then through extreme size differences in pulleys  §         As well as the simple addition on 10`s if not 100`s of generators ·        You get your many generators to spin many rotations o       That you are getting power out ofWhile your input motor only turns the once You have to make power    to all Who are in the Family of Christ
this is for the tribulation saints
how else do they stay alive + hidden
in our cold Canadian winters WARNING = the pre-Trib started on March 14th, 2012    joe lynchone_christian_warrior@yahoo.ca[/size]http://beliefstoliveby.yolasite.com/[/font]http://doorschristmustpassthrough.yolasite.com/http://www.myspace.com/one_christian_warrior[/font]http://www.facebook.com/one.christian.warrior[/font]http://biblefilescentral.yolasite.com/[/font]http://christian-war.livejournal.com/[/font]http://pre-trib-force.blogspot.com/[/font][/font]
