ENERGY AMPLIFICATION
DimaWari
Tnx Gyula,
But I believe it would be better if they were 90 degrees out of phase, so that the other coil can help to demagnetize the core?
gyulasun
Hi Crazycut06,
Yes, I also think that basically the pingpong toy principle and that of the shown patent circuit is similar, there are two differences:
Tesla used an outside energy source, connected to lines A and B  and Tito claimes to use  precharged capacitors, the other difference is that Tesla did not show any feedback path from output to input while Tito has described his circuit with feedback, 'suggesting' that the two caps can be maintained in a charged up state while hopefully some useful output power can also be had.
rgds, Gyula
gyulasun
Hi totoalas,
Well I would tend to suggest using ferrite E cores or similar but Tito has hinted on Tesla bifilar pancake coil configuration and these do not really have ferrite cores...
So what I think is if you happen to have in your "junkbox" some E cores then use them but you need two similar coils as primaries, to start with. Also the inductance of these primaries may be of importance with respect to the switching speed, low number of turns may not be a good start I believe. (I apologize but I am not yet familiar with Lawson circuit  of course the wire sizes you mention are good for a start, no need for rewinding with a thicker gauge.  Your 400V 2200uF caps sound fine, please charge them up only for 10 - 12V DC to start.
Good luck, Gyula
gyulasun
Quote from: DimaWari on February 03, 2013, 08:19:56 AM
Tnx Gyula,
Hi DimaWari,
Tito wrote:  "then if we alternately discharge the cap1 and cap2 there should be a middle coil or the collector coil as our free load"
I understood this as 180 degree out of phase and not 90 degree, this is why I wrote that when S1 is ON, S2 is OFF and vice versa.  It is possible that this would work with 90 degrees phase shift which would mean an overlapping switching sequence while the 180 degree is just not overlapping but alternating.  At 90 degree, you would switch into the previous switching state and demagnetization would use up extra 'juice'.
I assume you are talking about the primary coils into which the caps are discharged alternately, right?
rgds, Gyula
DimaWari
Tnx Gyula,
Its my mistake. I thought its the same with tesla electrical transformer. But here were talking about capacitor discharge while tesla use pure sine wave. And Its more like of a sawtooth wave when we dump the of capacitor charge into a coil right?
