ENERGY AMPLIFICATION
totoalas
the flyswatter , i damaged 6  long time ago
problems
are
1. prolong charging  damaged the circuit
2. continuous use of the output    -  only one time busted
3. if the output is left shorted and charged    -  one time only
4.  since it is only 4.5 v dc power supply input   ... need at least 12 v   for the  easy test set up
any help is appreciated    thanks   -   i want to loop using the load   e core   one side additional coil   for this
quote from phil B  Pro
When the flyswatter is switched "on" current flows through the biasing resistor to turn the transistor "on" and energize the transformer primary. The rise in energy in the transformer primary induces a voltage in the transformer secondary. But, a steady voltage in the primary will not induce a voltage in the secondary for long, only while the voltage in the primary is either rising or falling rapidly. The transformer also has a loop in it that feeds back to the transistor and over-biases the transistor so that it shuts  "off." When the transistor is "off," the current that over-biased it ceases because the current going to the primary goes through the transistor, and then the battery current through the transistor's biasing resistor turns the transistor back "on" so current again flows in the transformer primary. It is a simple and cheap oscillator.
crazycut06
Ok, In my experience repairing swatters the parts that gets busted easily are the transistors, they die if prolong used, you may try replacing the main primary transistor with a higher rating and with accessible heatsinking... Hope that helps...
totoalas
thanks cc
something to play around  this week
if i provide a dc supply source to both swatters and pulse the bifilar coils simultaneously for just an easy set up.....
need to finish this one before the holy week as i will be on vacation in Cavite .......
I want a stable pulsing circuit like a ignition coil from scooters  powere by my solar panels.. not a free energy but a useful one to supplement our food in the table instead of investing in Meralco electric company with rates compared to Japan and one of the most expensive electricity here in Asia
totoalas
Hi
in Part 2  precharged swatter battery 5 v dc  / caps c1 and c2  12  and 11.39 v dc  @ 1:45  then   start continuos charging   c1 18.4   c2  11.77 @ 11.59  @2:35   c1  32,6   c2   13,40 v  and oscillator/ swatter stopped due to drained battery
kEhYo77
Hi.
What do you think about this schematic?
If the breakdown avalanche effect of the diode is big enough we could have some interesting results :)
It is to be used as a few turn primary for a Tesla Coil (transformer). Having seen Primer Fields on YT, it is my belief that this PHI ratio clockwise / counter clockwise / clockwise type of primary winding will by very efficient.
kEhYo
