ENERGY AMPLIFICATION
0 Members and 68 Guests are viewing this topic.
forest
Quote from: Kev on March 12, 2013, 11:17:21 PM
Sorry, wrong link  ;D
This is the video: http://www.youtube.com/watch?v=KnJFonvzr1E
This won't work, it's only a starting point, better to use anyway like solar panel to charge big capacitor....
Qwert
Quote from: forest on March 13, 2013, 08:18:14 AM
It's nothing special; an old, pretty well known hoax.
Groundloop
Quote from: Qwert on March 13, 2013, 09:26:48 AM
Qwert,
The Ambient Power Module (AMP) do work. But you can not get any high power out of them. The AMP is
converting anything that is received in the antenna to DC power. If you use a metal plate as an antenna
and good grounding, then you can collect some energy from air that is not only radio waves. But the power
output is low and you can not run your house from one AMP module. If you build a lot of modules then you
can collect some few Watts of power. But you will need a LOT of them.
GL.
Kev
Quote from: Groundloop on March 13, 2013, 10:12:06 AM
Qwert,
GL.
Unless if we can amplify it.
-Kev
Magluvin
Quote from: Kev on March 14, 2013, 12:59:22 PM
-Kev
Yes. Unless. ::)
Its easy to say. Unless.  Unless.  It sounds funny when you say it too many times. ;D
What is an amplifier?  Well, the ones I am familiar with, only come 'close' to Pout being equal, let alone greater, than Pin. And these are real world amplifiers, whether they be RF, audio or even just a relay. A relay is an "amplifier". But in each case, there needs to be a 'power source' capable of greater than the desired output, even though the input 'signal' that we want to replicate at higher voltage and amperage, is small.
So when you say 'we amplify it', you are talking about a totally different kind of amplification than we are familiar with. ;) But, I understand what you mean.
You sound quite sure of it.  But if this is as much as you can tell us, then nothing will be accomplished except words on a screen. ;)
So ok, we make the circuit you presented. Then we 'amplify it.  Hmm, well why is does it seem to be a requirement to use 'this' type of circuit as an input, when maybe we could just use a large cap, that should be able to be replenished by the 'amplified output? It wouldnt take much to 'generate' an initial charge to get things going. In fact a shake flashlight or a small hand crank generator will build a charge faster than the 'circuit'.
Was just wondering about that.  ;)
Anyways, if you have any 'amplifier' circuits for us to see, Im sure everyone would be very appreciative. ;)   Otherwise, like I said above, its easy to 'say' "Amplify it", without a requisite of OU. ;)
Mags
