ENERGY AMPLIFICATION
0 Members and 254 Guests are viewing this topic.
totoalas
Quote from: gyulasun on September 15, 2013, 04:56:04 AM
Hi totoalas,
I have just seen your latest short video ( http://www.youtube.com/watch?v=mtxeynJ4UcA&feature=youtu.be ) in which you said you would not change anything in your working setup till the buildoff lasts. Yes, I agree with you and what I asked above to disconnect the ground wire is to be postponed then.  I think the ground wire is a must in this setup, perhaps Tito could confirm whether his setup also uses a ground wire or not?
Some time later you may wish to make a real schematics from your total setup  8) :)
rgds, Gyula
iM STILL GAZING AT IT WITH DISBELIEF IM TEMPTED TO ADD MORE LOAD BUT LIKE I SAID LET THE PMBO FINISHED BY 25TH WHILE I START DOCUMENTING THE DETAILS AND QUESTIONS IN MY HEAD WHY ALL LOAD GOT 100 % BRIGHTNESS
THANKS AGAIN
TITO SALAMAT BRO
gyulasun
Hi totoalas,
Thanks for the answers and is not it strange that a 63V DC rated capacitor has 287 V DC across it? IT is ok this cap is 79 V surge rated but it should blow up from the 287 V, no? If we mean the same cap: the big light gray on the right hand side next to the black one.
What do you mean : They act as neutral.. ? you mean the LEDs have a common connection point and that this point is what is grounded? And you consider this common point as a neutral point?
You do not mean you use the mains neutral as a second connection, besides a ground connection?  Sorry for this question, I do not understand what you wrote on neutral, and what you wrote to tinman I did not get yesterday under your video:  ...the caps kep on ringing without v decrease this i need to find out onlt the secondary plus neutral or earth ground is connected ...
Yes it is okay you wait till the end of PMBO of course, let your setup run.  In the meantime just check by your eyes how all the wires are connected and where they exactly go...   8) :)
Greetings,  Gyula
lightningengineer
Quote from: gyulasun on September 15, 2013, 08:54:01 AM
Greetings,  Gyula
I might be incorrect but I got the impression from his youtube video that he was using the Neutral line and earth line of house wiring.  If that is the case then this is nothing.  You can easy pick up all that amount of power with capacitors between the earth and neutral.
I dont want to see the schematic.  But he should take his setup outside and drive a spike into the ground and use that for earth.  He will see how quickly the power doesnt exist
Just being honest.
totoalas
Hi totoalas,
What do you mean : They act as neutral.. ?  The resonant transformer supplies the live wire  the earth or water tap  acts as a neutral   you mean the LEDs have a common connection point and that this point is what is grounded? And you consider this common point as a neutral point?   all leds are parallel  one leg to xfmr  the other leg  to water tap
You do not mean you use the mains neutral as a second connection, besides a ground connection?  no house neutral or live is used     the ckt pulse motor come from regular wall  220 to 12v dc and was cut off as shown in the video  orSorry for this question, I do not understand what you wrote on neutral, and what you wrote to tinman I did not get yesterday under your video:  ...the caps kep on ringing without v decrease this i need to find out onlt the secondary plus neutral or earth ground is connected ...the one zecondary directly connected to the leds the other end open
Greetings,  Gyula
totoalas
Quote from: lightningengineer on September 15, 2013, 09:14:13 AM
We have done this here long time ago  neuground lighting  please read back on this thread
Just being honest.tnx
