ENERGY AMPLIFICATION
0 Members and 224 Guests are viewing this topic.
Tito L. Oracion
@lightning E
peace be with you and may you rest in peace. ;D  joke
well, what can i say, i am not anymore want to quarel to anyone ok ;)
if you got something good in some of my post then good, and if not sorry.  :(
how come i'm lying when i'm saying the truth and you didn't get it?  :-\
agin agin agin. i'm a peaceful man and i'm contentented with some free stuff and that's all ok. :)
One thing that a man should learn is that, in your words you can hurt someone and sometimes you can make someone smile and from there you should choose what is good. and i'ved learned from that. i hope you too. ;)
and if you want to be respected, then learn. :)
@toto
ang galing mo bro keep it up. though your style seems to more dangerous, all in all its ok.
@gyulasun
i'm not using ground. that's an old style  ;D
God bless everyone
take care  ;D
otits
Tito L. Oracion
Quote from: lightningengineer on September 15, 2013, 10:32:52 PM
This will be the last thing I say at this silly site.  Unlike Tito I will GO for good when I say so which is something he cant seem to do although he has said it a dozen times but always comes back when his ritalin prescription runs lows.  LOOOL
Hey Tito....are you stupid or a Liar or both?  Everyone here needs to take a breath and consider this.
Logic dictates that IF IF IF you had overunity and half a brain then you should have made some small product that is dumbed down and be a millionaire.  So I ask again....are you are liar or just the worst stupid businessman on planet earth?
I think you are both.
Good day and happy new year to you all   LOOOL
hmmmmmmmmm ;)
We can actually see a man how his level of thinking isn't it.  ;D
just do that do this and that's it  ;D  lol bhahahahahhhahhahhahahhahh
You know what?, i am the quick brown fox jumps over the lazy mad dog. and you are the dog  ;D  joke
ya know what agin?, free energy is just a matter of capacitor and wire and some controllers.  8)
tsk,tsk,tsk you really need to learn. ;D
otits. ;) ;D
forest
hello Tito braveheart  ;D
tsk tsk please more tips  ::)  give us more of your joy
happy happy Tito  ;D ;D ;D
forest
why not two capacitors ? or a capacitor and transformer and a diode bridge to recharge capacitor...oops that was your original setup with batteries , right ?
greetings from Edison, he told me he was sad to not use his greatest discovery....you re-discovered  ;D
totoalas
Hi to all
Thanks Tito   so my set up is primitive  thats ok  will come to ur tech later
Gyula ANd Lighting Engineer    thanks for the enlightenment
Now   ive just checked my DC power supply
its a Sony WI II adaptor  wall outlet   220 v ac / 12 v dc
Heres the result
When power is on output is 12 v and sypplies 600 mA to rotate the pulse motor and same time the pulse circuit supplies the ignition coil
the water tap is connected to one leg of 8 parallel led lamps   which is partially lit   70 %
when I switched off the power  the lamps go to 100 % brightness
when  I removed the plug from the wall  the leds are off
when i removed only one   positive or negative dc wire
the lights are on when the adaptor is plugged in
so the present condition
wall adaptor plug switched off by switch meaning live isolated
output dc  wire is connected to the pulse circuit
and igition coil positive connected to positive output of pulse circuit  while negative to negative of input pulse
Conclusion
with open in/ output of wall adaptor  the water tap closes the loop via leds / IGNITION COIL  and reading 110 v ac
EITHER THERES A LEAKAGE  )or induction caused bt the ignition /coil cap to feedback to the positive and negative of pulse output circuit)  FROM PRIMARY GOING TO SECONDARY  WITH NEUTRAL STILL CONNECTED IN THE EXTENSION SOCKET ....
so theres no claim of OU   ONLY SEARCHING AND DISCUSSING FREE ENERGY AS THE FORUM SAY
PLAN B   STICK TO PWM  AND SEE WHERE IT GO
THANKS
