ENERGY AMPLIFICATION
0 Members and 50 Guests are viewing this topic.
forest
Magluvin
Two things to consider :
1.What do you have on you car roof ?  :P
2. What is the missing piece in patent we were working on for years on other thread , compared to real devices ....
Anyway, Tito ? I still don't know why Tesla needed high voltage ? It is not needed except in sending energy and I have no troubles to imagine it for sending it via stratosphere when HV would ionize path to energy to flow...but for ground sending ?
oh, maybe needed for  step down  to 230V because 1V AC is rather not usable ????    ???
I really need to know what was the construction of zinc-carbon battery used in 1800' for telegraphy to estimate the current/ voltage relation used to power telegraphic cables...
jbignes5
 Actually in the 1800 earth batteries were used for telegraphy.
http://en.wikipedia.org/wiki/Earth_battery
But officially these batteries were used but were very dangerous...
http://members.kos.net/sdgagnon/te4.html
As for your question about why Tesla used or needed to use High voltages, well quite simply there was little current for the high voltages to loose either in the use or in the transmission of that energy. As we all know that high voltages that incorporate high frequency show skin like effects on anything that it conducts through. Well Tesla figured that out and instead buried his grounds very deeply near water to use the surface of the water to conduct on. Did you ever wonder how Tesla planned on giving power to ships at sea? Ah ha! With an inverted system of grounding Tesla could pull this off. That means use the air as the ground and the ground or water as the medium of transfer instead of the other way around.
stupify12
Tesla's way of Electrical Energy Transfer is done by two things. First Hv discharge spark/arc, Second is by Vibration of matter through the ground.
Let me remind you dont ever think of electricity as a Electron Flow that is very wrong. Tesla's concept of electricity is the Vibration of Atoms(Magnets in nature), It is very clear on Tesla's mind that electricity is somewhat fluid like vibration(Domino Effect). Let as think of electricity as water/fluid.
Answer;
1.I still don't know why Tesla needed high voltage ?
Actually to attain Free Energy Devices we need to modify the energy input,. It is attain by using the disruptive discharge of the condenser on the primary ,think of it like how the joule thief work but in a controlled manner. The controlling of On and Off of the circuit it to amplify the energy and to avoid the so called Lenz Law. Tesla use HV to improve the efficiency of the High Frequency Generator, Hv means less Resistance- less losses on the generating set up. What was really the goal of Tesla is the phenomenon of the disruptive discharge of condenser- One can attain High Frequency with one impulse discharge of the Condenser. That is the reason why Tesla think of the condenser as the most wonderful instrument discovered on the universe. He  cited that there is no limit on energy we can create on COndenser.
This is the result of the disruptive discharge on the primary. When Tesla discharge the condenser the impulse of the discharge is rapid alternating oscillation inducing the secondary windings of COILS, with the condenser characteristics of impulse rapid oscillation Tesla can generate on the induced secondary coils HV(many turns) High Frequency. It is clear that the High Frequency and High Voltage is generated on the Secondary of the Tesla Oscillator.
2. What is missing on the patent?
There is nothing missing on the patent, the only problem is it is scattered on parts on all of the patents of Tesla, one must combine all the knowledge learn from the beginning to understand such genius man. The missing part is the difference of Radio Telecommunication and Tesla Energy Transfer. This is the difference:
Radio Telecommunication, The transmitter is connected to ground(EARTH) and works best when near a swampy(WET= better conduction) area for better performance. but the portable radio receiver/listener are not grounded , maybe using battery pack to power such radios.
Tesla Energy Transfer, The transmitter and receiver are both grounded. The propagation of the energy is through the ground or water bodies. The way the energy transfer is by Vibration of ground or water. Tesla way of energy transfer is by sending shock wave impulse of currents on the ground, then the receiver can receives this vibration with the ground connection of the primary windings.
The big difference between the two is; Radio Telecommunication is  sending electromagnetic waves, Tesla Energy Transmission is by sending currents to vibrate the ground/earth. The energy transfer will only work when this transmitter tower is connected to the receiver by the aid of HV SPARKS/ARCS. That is wireless done by Tesla, using only the ground and sparks/arc to transmit energy. Think of it simple, dont ever think of complicated ones, Tariel kapanadze" my secret is so simple that you will laugh" ;D ;D ;D
As for the Tesla car on my own idea, he is using a battery for buzzer type switching and the antenna is for air capacitance. Tesla utilize the capacity on suspended air capacitance, if he can produce 1volt on the antenna, he can amplify the energy to power hes car motors and recharge the battery at the same time.
With the direction of TURNS OF WINDINGS( examine it closely how did Tesla wind the coils on Transmitter and Reciever are they on repulsive or attractive orientation) with the transmitter and receiver Tesla is very sure that this Sparks/Arcs will only arcs to the receiver Tesla Oscillator.
The idea of wireless is simple with out using literally a wire, he wanted to perfect system that in the future we dont needed to spend so much money for the transmission wires.Instead Tesla use the Tesla HV discharge and the Earth as a medium for wireless. He doesnt use wire but use the HV and ground instead. Did you get the point guys. Tariel is using it on his Blue Vertical Transformer sending energy using the spark to connect the First and Second Transformer with the HV Sparks.
First 12v>Amplify> HV+ Hi freq>Step down>Low voltage 220v+ Hi amperage still Hi Freq. Try to Step down the 1kv by using the proper turns(voltage) proper coil secondary diameter(amperage) + ground electrons as people think it is electrons LOL. ;D ;D
stupimeow 8) 8) 8)
Quote from: forest on October 08, 2013, 04:36:49 AM
Magluvin
weizisky
If you want to understand Tesla >>and Tito well, you need know kick >>and transmission-line transformer well.
forest
Quote from: weizisky on October 10, 2013, 02:17:59 AM
Sure, but nothing replace the experiments ! Unfortunately some of them require tools :-(
