ENERGY AMPLIFICATION
stupify12
You circuit is correct. Also the winding direction is correct. But the only wrong here is forcing one head of core. Think of this picture I have attach and used it with your circuit.
Quote from: Dave45 on November 04, 2013, 10:00:50 AM
Iv been playing with this circuit a little, its a very interesting and simple but the sims have a hard time with it, a couple of people have got it to run in a sim but showing only conventional view + to - it would be very interesting to see it in electron flow - to +
What would you say is triggering the mosfet gate, I believe D1 and D2 are the trigger but is it bemf that triggers the gates or femf.
It will pulse two primary's from the center out and from the outside in but will not oscillate if one is reversed, its interesting if you use cw and ccw coils you are pulsing the primary's but the polarity does not change only the bemf collapsing into the coil changes the core direction, If all bemf were stopped from interring the primary's this would operate like a flywheel,,,,,,, you know ring magnets will only fit one inside the other if their polarity's are nsnsns.
Dave45
I read an article, I posted a link to it here that said magnecoster used pm on his cores to keep bemf from entering the primary and it makes sense bemf changes the core polarity if the core polarity could not be changed because of the pm then the bemf could not enter the primary or at least would rather inter a coil that whose core polarity could be changed, I think this could be accomplished using a coil setup like ring magnets a pm on the center core, a layer of iron wire wrapped around the primary's then a copper winding to catch the bemf , the center core's polarity could not be changed but the core polarity of the iron wire could so all bemf would enter the outer coil.
Sounds like a flywheel could be created
Iv also been pondering the idea of spark gaps being incorporated into the zvs, could it be done?
I hope someone with electronic experience has some insights, would appreciate feed back.
dave
Dave45
Quote from: totoalas on November 04, 2013, 10:09:14 AM
if you pulse both primaries at the same time as ive done  you can see the kick kick bak back  result    cheers
Hey Toto I hadn't thought of that sounds interesting  :o
Dave45
Quote from: stupify12 on November 04, 2013, 10:20:05 AM
Hey Stupify isnt this the same coil layout used in Tesla's egg of columbus experiment?
stupify12
Let me remind you. Tesla Primary is always 2 wound coils. Like the egg of Columbus Machine. Bifilar Pancake Coils. The one I attached is for AC to Dc Conversion with no Commutator being used on Tesla's time. I have reversed the Picture instead of AC to DC i made it DC to AC LOL. ;D ;D ;D. Which the royer oscillator is perfect for this Transformer set up. If TotoALas can post a schematic of Pulsing both the Primary Together then disregard my post. The post is for Flip Flop Royer Oscillator your problems of the Bemf  can be solved by this 2 Branch of Core, better used 2 Flyback Cores.
Meow ;D ;D
Quote from: Dave45 on November 04, 2013, 10:34:45 AM
