ENERGY AMPLIFICATION
d3x0r
Quote from: Dave45 on December 09, 2013, 07:52:05 PM
I have to be honest I dont see overunity in a simple primay to secondary devise, alternating current works perfectly with the rise and fall of a coil effectively using femf and bemf.
Maybe standing waves or plasma but not induction, personally Im going to play with the Rodin type coils to concentrate a spinning field and see where that leads.
If we could ever find a way to pull the energy from the core (collect lenz) then maybe, I have a few idea's that I will be trying as time permits.
dave
Right; I realized later... it was to take one change and make it 'upright' ... could rectify the current change into an absolute value...
a.king21
Here's an early design by Tito. You may need to reverse the trafo because we could be talking double negatives here.
Anyhow I've replicated it and it appears to be marginally OU.
It will  certainly desulphate a battery from the battery itself.
So the effect could be the desulphation.
However better component matching will certainly help.
I used a Tesla switch as an interrupter.
It uses the Tesla's ignition patent method of pulsing by effectively shorting the cap.
Tito has added a diode and a resistor.
Nice circuit.
This was 2009 I believe. Tito knows what he is doing. I am certain.
Grumage
Quote from: d3x0r on December 10, 2013, 10:45:13 AM
More of a thought experiment.  What if you didn't allow the AC to go all the way to the bottom... so you started from +1V to +3 V and only back to +1.  Would the magnetic field at any time (or current) be backwards?
Dear d3x0r.
In a " Nut shell " Figuera  patent !!  ;)
Cheers Grum.
d3x0r
Quote from: Grumage on December 10, 2013, 01:16:44 PM
Dear d3x0r.
Cheers Grum.
Okay; I don't have a core with 3 juntions.  I folded them all onto the center, and one loop around the outside...
9V battery; I dunno needs to be a much lower resistance swiper... or have a resistor in parallel that's fairly low...
but then it will get hot quickly ...
But yes basically the idea works...
https://www.youtube.com/watch?v=7AOYYiONhnA
Only one side was really participating... one driver side.  Mind you it is on ferrite, so there is an additional snap back.. I should remove the core and just go to the one coil
totoalas
Quote from: a.king21 on December 10, 2013, 11:48:27 AM
Nice circuit.
relay relaxation oscillator by wasatonic  in regards to the relay as vibrator
