ENERGY AMPLIFICATION
0 Members and 66 Guests are viewing this topic.
Magluvin
Whether Tito hands over any solid info is but to be seen.  I think that the references to Tesla and what he discovered, and the Ice Stone are needed to be found.  I Have read a lot, but it seems tesla dicovered many things, which one?
Dont worry forest, I think we are beginning to pick up steam here and others are joining in, and many are watching.
Im not trying to go off on a tangent with new ideas, these things just pop in my head. So I tell as they are interesting.
Ok   time for lunch and back to the bench.
Mags
Magluvin
Just a quip
What if in Teslas Peirce Arrow, 80hp ac induction motor, and a tiny cap across its leads, and give it kicks.
Would the LC oscillate? Would the AC motor run while oscillating?
If a pendulum looses distance with each swing, a tiny kick on each cycle, will enable the pen to increase in height.
That kick needs to happen when the pen reaches top of the climb and stops. The smallest amount of kick will add to the system.
Ok lunch.
Mags
pese
Quote from: Magluvin on October 03, 2010, 02:28:14 PM
Just a quip
Ok lunch.
Mags
The LC(R), will not oscillate if no power will comes additionally
to  fill up all power-losses !!
2.
If you will take out Power from
the LC resonating circuit ..
(equally over transorming coil or mechanical via motor rotation.
IT IS NECESSARY . To put (at minimum!) equivalent POWER as
INPUT to the Circuit device.
3.
ALSO TESLA have take an "extern" power in his "Pierce Arrow"
Car, even he have not explained the "working" of the 1,80mtr
Antenna , and not of the used Vacuum tubes.
Gustav Pese
www.alt-nrg.de/pppp
angryScientist
Just a quip
Ok lunch.
Mags
You can put a capacitor across a motor and it will oscillate, some what. It will make the motor more efficient. What it does is change the phase between the current and the voltage. It's a very common concept. It's known as "Power Factor Correction".
Magluvin
I know that there needs to be supplemental energy to keep the motor running.
1  We cannot leave out the possibility that the motor was not modified.
     We all should know that a bifilar coil creates a stronger field than a normal coil of the same wire and total length and resistance. If you wind a nail with 100 turns of 20 awg wire  then another nail with 2 of the same wire, 50 turns each alternating eachother, total of 100 turns, put those 2 coils in series from opposite ends, each nail will read the same ohms. And will pull the same from the source. But the bifi will have a much stronger field.  Try it.  And what of trifi?  Quadfi?  Teets claims Trifi.
If we could take any motor that runs 90%eff(some are better ;]), and rewind it bifi or trifi, will we be over 100% eff if what I said above is true?
2  One of the stories of the few about that car, there was a single 12v battery in the car. Others there were not.
    If it were in the car, lets say that the lights needed power, horn, box of 12 tubes and resistors under the dash?
    Not to say that the battery was not replenished as needed by the system. Maybe it is the SPRING of his design, as to one of my circuits above that eventually no power comes from the source, but as the circuit continues working, the source SPRING is still necessary to allow the circuit to continue.  Just speculating. =]
There are many ways we can go with this.  But Tesla was all about efficiency, and beyond.  If that car existed, you can guaranty that the AC motor was of his design, and maybe  1 of a kind.  I lean toward bifi mods if I had to lay my Aces on the table.  Lol  I wonder if those rods pushed into the box were tuned for delay in the box, if they were iron. Or the C of the lrc.
remember what Teets said once, I use coil for coil, coil for capacitance, coil for resistor,  well there is resistance in a coil and in the leads of which all need to be added as the whole to come up with the R in lrc.  So an LC circuit could have a good R value without additional resistors. And The coil coild have a good C value if designed properly.
But hey,  these are just my thoughts not my claims.  Stuff to examine and work towards. Some new some old. =]
Mags
