ENERGY AMPLIFICATION
0 Members and 74 Guests are viewing this topic.
Cadman
Random thought. If, as I have read, the earth is a source of free electrons, has anyone ever thought to put a diode in the earth ground wire? Thinking about a battery circuit here.
Grumage
Quote from: Cadman on January 23, 2014, 02:16:21 PM
Avremenko did !!   ;D
wings
a.king21
Done it loads of times.
The only way is through elevation into ground. (Tesla) (Plauston)
synchro1
Aaron Murakami,
"A good way to find a good spot to put a rod is to get a multimeter and put it on DC volts. I had some long wires and alligator clips attached to the ends of the probes and the other end I had 3 foot rods...one steel and one copper. I would put one rod in the ground...doesnt' matter what rod you use for what charge because you're just looking for the largest potential difference you can get. One rod in ground...deep, then take the other rod and walk around with it sticking it in different spots. Wherever you get the highest reading, leave the second rod there.
Then mark where the first rod is, take it out and see if you can find a higher reading with it somewhere else, if not, put it back. If you get a higher reading, you can take the other rod and move it around and go back and forth. You're lucky if you can get 2 volts. I found 4 one time in my Qigong Master friend Rodger's backyard.
Anyway, this will show you some good spots either plus or negative.
For the TRV discovered rod method, it takes one rod...not for grounding purposes but to draw the aether from the ground.
EARTH -----> ROD -----> DIODE -----> POSITIVE ON CHARGING BATTERY
That's it! The TRV session was for logical next step enhancements to the overall SG circuits and with research combined with the data, the above is what it revealed. The line on the diode should be on the side of the battery so the positive voltage potential moves from Earth TOWARDS the charging battery positive terminal.
Please have a look at John Bedini's Earth Rod below:
