ENERGY AMPLIFICATION
0 Members and 67 Guests are viewing this topic.
Google
You can now make supercaps at home using :
Paper towels, lemon juice, activated carbon charcoal used to clean water in acquariums and two copper clad PC boards.
Can be used anywhere you need.
Picture enclosed.
Best,
bbem
Quote from: weizisky on October 16, 2013, 05:28:52 AM
Hi Gyulasun, everyone
Gyulasun you are absolutely ringt. Then we can know which tank is easier to transform and  stimulate energy to another tank in what kind of energy.
If you get that, you can understand ALL TESLA COIL working method. and will know which enventor's device does work., which one does not work, which one is better, which one is not. and Forest also can know why Tesla always use HV in depth.
so, you can make your free device now.
one more thing you have to think, where the free energy come from? It is not from eath, air, Zero pint, it also not from cap, coil !!!
if you get anwser, to make free energy is a piece of cake .
Hello Weizisky,
Thank you for sharing your wisdom with us.
About the hint you gave to forest; Is the statement above what you meant with checking Tesla's transmitter?
BTW are you using Tesla bifilar pancake coils in the ozon circuit?
Regards, Bert
Quote from: weizisky on October 16, 2013, 03:29:46 PM[/font]forest:actually free energy comes from resonance and resonance must be in resonance with energy which is directly powering Earth tell us a method of making free energy. not the source of free energy come from. the free energy come from the electrons which impact each other between resonance tanks. maybe it's not easy to understand that, because you dont have electron's model. free energy in above resonance tanks mean electrons kick other electrons, result: get more energy.
[/font]
Google:
My comments after >>>:
>>> I am only responding to a few of your comments to start with some basics.
Here is a simple circuit that needs very fast switching and will solve the puzzle. Just replace the LED with a 12 volt to 12 volt xformer. And use a strong 12 volt battery as a source, so that voltage doesnt drop when you are shorting the cap with battery during switching.
>>>  You should draw the transformer version of the circuit so there is no ambiguity.
>>>  The battery is separated from the capacitor by a 1kohm resistor so there is no need for a strong battery.
>>>  Can you draw a timing diagram for one of the circuits?
Faster is the switching, longer the battery will last.
>>> What is the reason for that?
You may also use arrays of old time diodes No. 1N5062. Each of 1N5062 will supply approx 0.35 volts in sunlight, flouroscent or any other light source but with good current.
>>> Have you ever measured the power output?
Magluvin
Quote from: weizisky on March 28, 2014, 11:47:36 AM
Hey Mags
the C2 itself is a out put circuit, C2 will release  a volume of electrons  between the two C2's pole plates to produce ozone.
you also can place a L3 to feedsome energy back  to the source, it's up to your need.
Thanks Weizisky.  I am not understanding the ozone part.  Also, are we talking about a special capacitor?
Mags
Google
Quote from: MileHigh on March 28, 2014, 09:31:17 PM
Google:
Thanks Sir MileHigh,
I will soon draw the detailed circuit and post for scrutiny.
Best,
