ENERGY AMPLIFICATION
0 Members and 154 Guests are viewing this topic.
gyulasun
Quote from: forest on May 04, 2014, 04:04:40 PM
Well, I have the same requirement... a super fast diode with breakdown voltage at least 600V and rated for continous current of at least 60A with pulsed current 400A or more...hard to find such one at resonable price...
What you mean on reasonable price... These types are close to your specifics: http://www.digikey.com/product-search/en?pv914=210&pv914=37&pv914=312&pv914=313&pv914=216&FV=fff40015%2Cfff8007f&k=silicon+carbid+diode&mnonly=0&newproducts=0&ColumnSort=0&page=1&stock=1&quantity=0&ptm=0&fid=0&pageSize=25
In Europe, Infineon manufacturers such devices.
Dave45
Ouch $106.00 for a 1.2 kv 50 amp
but what would you pay for free energy  :)
that_prophet
USE PULLEYS TO MULTIPLY ROTATIONS = AC POWER
What this Christian Warrior is trying to get out to the world,
is the simplicity of tHis Gift.
Free Energy is here + now, even free of all patent fees =
please Goggle free_energy + yolasie.
http://free-energy.yolasite.com/
free energy can be made simple,
you can use pulleys to multiply your electricity
instead of using oil to generate it
free energy is here now,,,
It is all done with pulleys. (mirrors of physical properties)
you use a small amount of electricity to rotate a very large pulley only the once,
then you get many times the power back out,
from the one or few generators connected to the same belt as the large pulley,
(rotating tens to hundreds of times the large pulley) all on the same belt
If you would like to know where this warrior is coming from,
please check these pages out :
http://beliefstoliveby.yolasite.com/
http://fire-starter.yolasite.com/
for my mission, Please view any of these Bible web pages:
http://doorschristmustpassthrough.yolasite.com/
http://decimationofthisevolutionfairytale.yolasite.com/
http://askthatprophet.yolasite.com/
but no one will listen to the simplicity of it
all you do is put power into a motor to turn a large pulley only one revolution
and then you get massive amounts of electricity back
from the many small pulleys attached in the same belt
It's workings are super simple
You put power into a motor to drive a large pulley only once (little energy)
+ You get out a multiple of that electricity
Depending on how small the generator pulleys are
As well as how many generators with little pulleys attached
With the amount of belt that goes around one large rotation
You can easily get 10 – 20 times the rotations of the input pulley
Then you can double your rotations each time you add yet another generator
On your own belt system, (easily done – takes little torque)
I figure, you simply must gain a multiple of the energy that you put in
As you are only putting enough power into the drive motor to rotate it only once
And you get back many times the electricity
Not only having smaller pulleys,
But gaining more rotations per foot of belt that you go through
To double or tripling your rotations by adding additional generators
on their own mini-pulleys
Free Energy is such an obviously simplistic discovery,
- as well as being extremely free + easy to produce,
what is the only reason for us missing this basic idea,
- we have been dumb to this free energy technology .
This technology has been hidden for far too long,
Please, go to this website
Search free-energy + yolasite
Or if this website allows URLs
then try your hand at producing a digital prototype
on one of the many free electronic simulator software's out there,
that will help start producing electric toys + tools,
and how about everything that runs on electricity,
being reproduced with free energy power supplies built into them.
Let's restart our economies,
by building industries that reproduce all of our electronics,
so that they are all self powered. (non polluting)
= First though, is getting rid of all the gasoline motors in our motorized vehicles,
and putting a GEM in them.
All we need to do, is have enough faith in His Word
to build these GEM (Good Electricity Multiplier) Miracle motor
THIS DOES INDEED WORK
(think about how simple this is)
(you put power in to rotate one large pulley once)
(you run a belt to rotate mini-pulleys many time)
(then you could add many mini-pulleys)
(each one rotating hundreds of times)
(multiplying your AC electricity)
(YOU MUST GAIN FREE ENERGY)
LOGICAL REASONING
It takes little energy to turn a one foot circumference pulley,
which can be used to drive a belt that turns a mini pulley
of one inch circumference many times
This 12X you gain your AC energy from the many times the small pulley rotates,
or even more from the many generators on mini-pulleys you add (no torque)
you can twelve times the AC electricity with every extra genertator attached
12X + 12X + 12X + 12X each starts to add up very quickly
all of these generators run free of any torque
come on guys + gals, this is so simple that it just has to work
you only put the small amount of energy to rotate a big pulley once
and you use pulleys to multiply your rotations many times
you could have ten mini-pulleys rotating hundreds of times
you simply must gain electricity
the torque is your only problem
and that would be minimal
if you only had a 12 inch circumference pulley
then you have 3 mini-pulleys
rotating 36 times for each one rotation of your large input pulley
YOU JUST HAVE TO MULTIPLY YOUR ELECTRICITY
a.king21
that prophet.
Words are cheap. Prove it by showing a working prototype, or no-one will take
any notice.
gyulasun
Quote from: Dave45 on May 04, 2014, 05:45:06 PM
Hey Dave,
It is interesting that you pick the most expensive from the list shown in the above link...  so yes, free energy can be expensive  :D
There is the 1.2kV  99 Amper for $37.57 (APT30SCD120S)   or the 1.2kV  68A for $26.44  (APT20SCD120S)
Gyula
