ENERGY AMPLIFICATION
0 Members and 110 Guests are viewing this topic.
Tito L. Oracion
Quote from: Bob Smith on May 24, 2014, 10:32:03 AM
I can't help but wonder if this is why they made the Thor movies. Maybe they're a glimpse of the future source of power in Thorium.
I still prefer to search for Titonium.  It even glows! ;D ;D ;D
Well, Titonium is just like lighting up a candle, once you lighted it then the system will run forever.
simple and very easy to do even a five year old can do it.  ;D
but in thorium we only need 8 grams to cover up a century of energy needs. and that's WOW  :o
;D
Tito L. Oracion
Quote from: Neo-X on May 25, 2014, 04:31:12 AM
I think im going insane not bcoz of im always thinking ou but bcoz of my sister in law's insane attitude.  >:(
Just treat her nice always and give her surprise gifts. and she will love you promise!  ;)
Tito L. Oracion
I believe somebody got it now,
and i believe  he is now becoming greedy and liar   ;D
and prohibit himself talking about it already  ;D
Neo-X
Quote from: Tito L. Oracion on May 25, 2014, 05:29:54 AM
I think it wont work bcoz she is super maldita at sobrang taas ng tingin sa sarili feeling nya ay napakatalino nya ubod naman ng tanga lahat nalang ng ginagawa ko eh pinupuna tapos kung makapang asar eh tagos hanggang buto kaya ako bwisit na bwisit sa babaeng un.  >:(
Bob Smith
Hi Kids :)
For your consideration:
QuoteThere were two layer windings.  The inner layer was the standard Joule Thief wiring.  The outer layer was similar except that the four wire endings were connected differently.  Two pairs of continuous looped wires were produced.  I could use that as two Secondary Limbs or I could connect them to produce one long Secondary Limb.
The Magic is to use the Joule Thief circuit as the Primary of the Transformer.  The magnetic flux induced by the pulsing Joule Thief leads-out electron motion energy as predicted.  Some of this lead-out energy is transmitted to the Secondary.
Thus we can demonstrate overunity easily with our two oscilloscopes.  We only need to have a LCR circuit in the Secondary to demonstrate overunity.  A COP > 10 was achieved.  Much higher values were also possible with additional tuning.
We can thus lead-out as much energy as desired.
Source: http://www.overunity.com/8825/pulsed-dc-transformer-with-embedded-magnets/msg248749/#msg248749
QuoteThe outer layer was similar except that the four wire endings were connected differently.  Two pairs of continuous looped wires were produced.  I could use that as two Secondary Limbs or I could connect them to produce one long Secondary Limb.
Hmm. This sounds like series wound bifilar... heh heh.
So, if we had an antenna gathering electrostatic energy (like Moray might've done), dumping into a small capacitor, then discharging into a joule thief, stepped up with a resonant bifilar secondary...  and perhaps added a pickup coil?
Now, I believe the windings on the primary, secondary and pickup have to be identical, in order that they resonate together.
For this to be really effective (according to Lawrence Tesung), we need to have the JT primary and secondary in resonance, producing a standing wave. But in the Don Smith device, which I believe may share similar elements to the Titonium :), we need to make sure that all 3 coils are identical so that they resonate together at the frequency applied.
That's all for me right now.
Bob, the Titonium hunter.
Edit:  Not trying to get off-topic, just a further clarification on the above post and its quotes to improve device:
QuoteWe tried the three layer toroid.  The first attempt was to put the Joule Thief at the lowest layer and two transformer type windings as two top layers.  There were some improvements but the top most layer showed significant decrease in induced voltage.
We then put the Joule Thief as the middle layer.  To our greatest delight, the Output shot up.  The continuous Output Power was 56 watts.  The steady AC Output Voltage was 14 Volts even though we varied the load â€" resistors and LEDs.  The Input Power from the 1.1V AA battery was less than 0.4 watts.  That gave us a COP of greater than 160.
It looked like we could get closer to resonance and extract much more lead-out energy with the new arrangement.  In a few days, our Output Power increased from a few watts to over 50 watts.  Our team is extremely optimistic in producing a 1KW lead-out energy device in the very near future. The following are a list of possible areas of further research.
1.   Size of the Toroid â€" Bigger appears to be better.
2.   Number of turns of wire in the Toroid â€" More appears to be better.
3.   Core material of the Toroid â€" No concrete data to show direction yet.
4.   The use of capacitors in the Joule Thief â€" appears to help
5.   The transistors in the Joule Thief â€" the larger ones appear to help
6.   The LCR circuit in the Primary of the Joule Thief â€" tuning helps
7.   The LCR circuit in the Secondary of the Joule Thief â€" tuning helps
8.   The LCR circuit in the Secondary of the Transformer â€" major factor
9.   The number of turns of wire in the Secondary of the Transformer â€" important to connect the right way â€" mixing clockwise and anti-clockwise will lower output.
10.   The use of thin copper wire appears to be much better than the lamp wire.
11.   Use of Signal Generator instead of battery â€" can vary frequency.
12.   The lower the frequency, the higher the lead-out energy (results so far).
13.   Higher L and Higher C values appear to lead-out more energy.
14.   The Pulsing can either be AC or Pulsed DC.
15.   The present Joule Thief and Transformer arrangement appeared to have build-in feedback mechanism.
16.   The Output is capable of recharging batteries now.  We can already demonstrate Battery A recharging Battery B and vice versa.  A few (6 LED lights) could be on all the time.
Source: http://www.overunity.com/8825/pulsed-dc-transformer-with-embedded-magnets/msg249150/#msg249150
Note: Tseung proposes air core as the optimum for desired effect.
