ENERGY AMPLIFICATION
0 Members and 142 Guests are viewing this topic.
forest
well,I thought only how to make it more efficient because I think this is the essential part of Don Smith table top device secondary,he just used special coil
Magluvin
Hey ,  been way too busy lately. I have been doing some research and a few tests on things though.
While I was digging through some of my stuff, I found a couple neon transformers used in scanners and thought to give the Arvmenko Plug a shot.  I am impressed.
Its in 2 vids.  The first vid was cut of due to the camera shutting off when I discharged a cap at 700v. Mini EMP. ;]
I have only tried it this evening and havnt done any current tests on the input.
But the vids show what it is about.
But how many plugs n caps can we charge with this method?
I have some parts coming in hopefully this week. I ordered some SIDAC devices which I have read them to be specified as solid state spark gaps.    Would those be silent explosions?   We shall see.
http://www.youtube.com/watch?v=6U3L5wD-TLI
http://www.youtube.com/watch?v=Bf40Lyqyx4A
It is taking long for the vids to load    they are still loading, the second one anyway.   I am going to sleep, the second one should be up in a bit..
Mags
wattsup
@Magluvin
If you have a second capacitor and two more diodes, you can do the same thing off the other circuit polarity. Or try the capacitor on the other circuit terminal. If you have two capacitors one on each terminal on one wire each only, then you should double your output without creating that much additional load on the circuit.
Also, you can try using a lower voltage rated capacitor but with a higher mF rating and use it as a real tank, then try to send some of that juice back to your battery through another diode and a resistor so you do not deplete the capacitor to fast. Or even through a 12v zenor diode that will shoot pulses back to the battery at a certain voltage rating.
One question. Is the output of the circuit AC or DC?
forest
Mags
Can you find device called Trisil ? It seems much beter then SIDAC.
Can you find the exact name for such device ?
Attached is comparision.
forest
Mags
I've found that connecting a big stranded copper wire to the big iron thing or copper tube grounded speed up capacitor charging many times. Can you try it ?
Just connect it to the capacitor negative terminal (where diode connect to it from anode).I suspect that it works like a pump and take electrons from metal.
The rate seems also proportional to the voltage of incoming wave.
I'm sure there is plenty of electrons everywhere generated by our Earth, just "dormant till cycled"
