ENERGY AMPLIFICATION
0 Members and 38 Guests are viewing this topic.
Dave45
Mark
Is this what you meant
I need to do some testing but I dont think the extra diode is really needed if the coil is wound right, ie parallel windings.
stupify12
Semi conductors are the ones that stopping you from realizing such great idea. I would suggest you only work first with Relays then Vacuum Tube Triode, for semi conductor the only good piece I can see is the JFET.. Semi Conductors cant give you enough power to the device you wanted to build, it will only restrict your design. This is the reason I give up on using Semi Conductors as switching device.
Now review the history of Free Energy Devices do they used semi conductors on their time?
Tesla
QuoteWell, in some of these bulbs I have shown, for instance,
that a heated conductor emits a stream of ions, or, as I said
at that time, charged particles, and a few of these bulbs I
have been using exactly in the same manner as the audion is
used today.
Meow
Quote from: Dave45 on August 22, 2014, 07:21:42 PM
Mark
Tito L. Oracion
MarkE
Mark
Dave something like that.  You have freedom to choose  what voltage drop you wish to have where the diode is up to the voltage limits of the switching device.  The tradeoffs are:  More voltage ostensibly pulls more charge from the surroundings, but dissipates magnetizing energy in the coil faster.
MarkE
Quote from: stupify12 on August 22, 2014, 07:47:19 PM
Tesla
Meow
If one does not restrict the voltage somehow then one invites arcing across there contacts as those contacts open.  That wears the contacts and it dissipates energy as heat.
