ENERGY AMPLIFICATION
0 Members and 83 Guests are viewing this topic.
zdiblo
@Zd: making proper measurements, being able to communicate and share those measurements, and discussing the use of well-known techniques to improve performance of commonly used systems,  is NOT off-topic. Sorry that it isn't simple enough for you, but there it is.
I´m sharing....energy amplification...sorry for my english...
https://www.youtube.com/watch?v=bFDVCm-pxKw
https://www.youtube.com/watch?v=9oyrzLmyxeQ
MarkE
Quote from: TinselKoala on November 25, 2014, 11:43:17 AM
I think your scope has an external trigger input. This is what you should be using if you want good time synchronization between the A and B channels, and use "ALT" mode for the "System Y". Use the gate signal from the microprocessor, (or another output of the MCU that is synchronized with the signal fed to the mosfet gate) fed to the external trigger input of the scope. Top right BNC jack in the photo, if I am understanding the layout correctly. I also found the Service Manual but it's in Polish of course and I can't read it.
http://elektrotanya.com/kabid_dt-525a_oscilloscope_sm.zip/download.html
I think forest is probalby using alternate sweep and auto trigger.  Set the trigger to normal and things should work fine.
Quote from: zdiblo on November 25, 2014, 01:00:15 PM
There is nothing wrong with your English. But you must know that voltage is not energy, power is not energy, and there is a huge difference between peak power and average power, no matter the language used. The claim in the second video that "there is no way that the power from the wall gets into the ignition coil" is simply a baldfaced lie: All the power being shown in the output of the coil does indeed come from the source: the mains power connection. In addition, it appears to me that the coil is incorrectly connected for the "weak spark" and becomes correctly connected for the enhanced spark. I'm not sure about this, though; is there a complete and honest schematic somewhere that I may inspect?
Now look at this, running on a 24 volt battery supply, NOT a wall socket.
http://www.youtube.com/watch?v=M9KVTJQsnE4
(Of course the power used to charge the battery in the first place did come from the wall socket.)
Quote from: MarkE on November 25, 2014, 01:05:45 PM
Use the external trigger, directly from the clock, and there will be no doubt. Oscilloscopes incorporate that feature for a reason, it's not just for show or to pump up the cost.
zdiblo
Quote from: TinselKoala on November 25, 2014, 01:16:24 PM
Thanks for clarifying me and forgive me for intruding, I am not an expert in electronics like you, I am simply someone who would like to discover something in this area for pleasure and own satisfaction.
Can you please tell me if you already got an OU unit?
all the best ...
http://www.esmhome.org/library/aaron-murakami/radiantwatersparkplug.jpg
http://freeenergylt.narod.ru/olderfiles/6/FREE_ENERGY_8.jpg
or
http://4.bp.blogspot.com/-r9LBLk0Lwn4/TjaUt6ao9jI/AAAAAAAAAFg/4zcJz7J_beo/s1600/schematic.GIF
I´m just a newbie.....sorry....I think no one post the real schematics on the web....
Zd
