ENERGY AMPLIFICATION
0 Members and 80 Guests are viewing this topic.
bboj
Quote from: TinselKoala on May 26, 2015, 07:31:49 AM
Do you not understand that pumps like that only pump a _fraction_ of the water that is supplied? Look at the right side of the drawing, do you see the exhaust ports? Most of the water that comes in to such a pump is vented overboard at the level of the pump and only a small portion of the supplied water is actually pumped up to higher level.
nevermind
Dave45
Battery charging circuit
nelsonrochaa
Quote from: Tito L. Oracion on May 26, 2015, 06:54:11 AM
Actually i'm just talking about bigger version then to rotate a generator using a continous flowing of water. :D
high voltage to low voltage is not always work in some cases, the secret is accumulation.  ;) 8) :)
Consider this: if you have a small flowing of water into a big tank, then using that big volume by a small fraction to create a big boom. ;) 8)
I Tito , good "simplification" to show the basic concept that Nikola Tesla explain in some of their notes  ;)  There are people who still will not be able to see the obvious because simple ignore the more simple and evident phenomenon that are present in every day .
The most big things born of small and simple ideias , now people like "complicate" what are simple .
People not understand the real meaning of discharging a capacitor have the same effect of  a big "hammer hitting with full force" when discharge. We can discharge a big capacitor to a smaller creating a pulse of high "hammer hitting".
I understand what you try to explain.
The other thing that people need to understand is that capacitor is not filled with load of current feature but with BEMF.
Sometimes i see people near to achieve and be presented with this beautiful effects  , but in an instant, some people introduce "noise" diverting people from the right path.But maybe it is intended to be so or not ....
Most of these people only know to criticize however the "wisdom" of them, is far from're talking about.
Good luck to all
https://www.youtube.com/watch?v=3S4lCUvzn0E
https://www.youtube.com/watch?v=fnpB_gqH6HU
Dave45
QuoteThe other thing that people need to understand is that capacitor is not filled with load of current feature but with BEMF.
I guess it would depend on the circuit but if you charge one side of the cap with bemf (positive), then the ground side is charged as well, negative.
Magluvin
Was just looking at super caps on a site.  Seems most are 2.7v at what ever hundreds to thousands of farads. Then I was thinking, gee, say 500F cap is 2.7v, if I need to operate at a higher voltage, I would need more caps in series.
Typically we are trained to think that caps, at say 1000uf 10v, in parallel will increase the capacitance. So 10 of these caps would be 10,000uf.  Correct?
So now, we take those 10 caps and we put them in series. What would our total capacitance be? ;) ;) ;) ;) ;)
Maybe this is nothing new or special. To me it is, or it seems so at the moment.  Does anyone have an answer? ;D
Be back in a bit. Eat and showa.
Mags
