ENERGY AMPLIFICATION
0 Members and 47 Guests are viewing this topic.
Enjoykin2017
Quote from: Magluvin on October 05, 2016, 09:06:57 PM
Ive just learned over time to mostly be able to see what happens in these circuits. So noticing the position of the break in the circuit made me look twice.
So in a way this design probably doesnt have heavy burning of contacts, if the timing of the 'make' is in sync with the resonance of the large cap and primary LC, of which that freq may be altered by the secondary with what looks to be an extra coil. Lets say for instance that when the large cap and the primary are in resonance and say it simply may have only 300v swinging back and forth, 300v+ to 300v-.  If we were to charge up the LC to the 300v point and take away the input all together, each resonant cycle will diminish in voltage. Lets say it drops 10v for each half cycle, possibly being conservative on that number, but its just an example.
So +300v to -290v to +280v to -270v and so on till the oscillations stop. And the drop wont be linear like that, but just getting to the part of what the break has to accomplish.
So the LC is at + 300v and the break opens, and the LC ringing swings to -290v and then back up to +280 and the break closes again and only has to replenish the value of the voltage drop of 300v to 280v. Its only a 'Possible', for this hypothetical example, 20v difference that has to be replaced for each cycle loss. So this is a variant of a circuit that would have abrupt discharge into a coil from a cap, like the wind up tapper machine that made the building shake, where this circuit helps just maintain a particular level of resonant operation. Say the tapper could make the building to rumble dramatically, well then this circuit could help it just maintain a lower oscillation, or like once we got the building into a lesser oscillation and didnt want to go any further, then we could reduce the output of the tapper to only emit just enough to maintain that particular oscillation, like what this circuit looks like its intended to do.
Mags
Hi Mags
Yes you are quite right about described process in primary LC. But remember what Tesla said about primary excitation. Only unipolar HV impulse was permitted for primary LC excitation. Or in the other words unidirectional switch with infinitely short open and close times. This is a real probem how to get that HV Uni.-pulse. Amlitude shoud be very high more than 20 KV with no swinging current from primary to HV power supply and vice versa. Only fully controled clean and sharp HV Uni.-pulse. For that purpose he had made several kinds of unipolar spark-gap dischargers and the best one had shown was Magnetic Disrupter Spark-Gap. Find Tesla patent how to make one. That magnetic discharger give bunch of conducting electrons (from charged HV capacitor) terrible speed wit giant huge inertial forces while accelerating with astonishing 12 Mega Volts accelerating volatge (in Teslas case he used that).
What will happen when so huge accelarated bunch of electrons sudden stike massive copper primary coil on his way ??
There come play new physical process or preciselly new sort of aggregate state of matter - Aetheric Matter. In my oppinion this matter was "hard packed" in inner shell of electron/s. Remember that mass of such "packed matter" in electron volume exceed 15 000 ton/cm3 and we simple release that giant packed aetheric particles out of electron shell and they continue to fly out to target - primary Tesla coil with the giant accelerating speed only under inflience of huge inertial forces.
What is really going on than these accelerated Aetheric Particles hit giant number of electrons in massive primary coil of Tesla Transformer need to be researched very carefully. Remember Radiant matter paticles (Aetheric Matter) in forms of strong Radiant rays (very similar like light rays)  totaly made charged (electified) any metalic suraface which were exposed to Radiant Rays even on very long distances.
So until we have got a pure Radiant rays we can not make nothung in sense of Overunity and Self-Running generators. Yes Mags we definitely need that new kind of matter.... Aether Matter released from intrinsic volime of electrons. According to John Ernst Worrell Keely that Aetheric Matter possess highly vibratory state for all own coupled particles - that means possess giant kinetik force field which is direct responsibele for new kinds of matter transmutation process.
Could you make experiments with Magnetic Disruptor Spark-Gap and see what is going on ??
Reg.
Enjoykin
ps: Nice experiment with your car ignition coil.
Bob Smith
With regard to unipolar impulses, Tito has mentioned multiple times the importance of a unidirectional impulse.
I believe the AV plug is all that is needed to accomplish this.
Bob
Magluvin
Thinking about this coil in Don Smiths device...
The primary is the inner red positionable winding. When it is running, is the red coil between the 2 outer coils, centered? Or is it in the position shown in the pic?
If it is like the pic, then the red winding stimulates the outer coil it sits in, which has the cap across it on the terminal block to the right, then I wonder what the output of the thing is coming from. Its looking like the 2 diode duos put the 2 outer windings in series to load the caps on the far right.
If this is what is going on, is the outer winding closer to us in the pic being induced by the red inner winding or is it getting it from the far outer winding?
Usually an inner coil as shown has a lot less influence on an outer coil would have on an inner coil. Air core.
So I wonder about the logic of the inner primary and is there advantage doing so vs the other way around.
Dunno.Something is just clicking a bit when I look at it.
Mags
Magluvin
Ah. I missed something with the diodes. It looks like the 2 outer coils would have to be out of phase in relation to each other to charge the cap or one dumps to the caps in one direction of oscillation and the other coil dumps in the other polarity.
But Im concerned with the coil config. How do those 3 coils interact if the red coil is inside only one of the outer coils.
Mags
Tesluh
I believe the length of primary being 1/4 of secondary has to deal with its size which is why its inside the primary, if it was outside with the same length of wire on the coil it would barely be 2 turns.  I am also playing with this device and trying to build one that does what it was said it should.
