ENERGY AMPLIFICATION
0 Members and 45 Guests are viewing this topic.
Tesluh
and if anyone reading this hasn't figured it out already, lancaIV is providing some kind of attempt (possibly automated) to derail any conversation that deals with figuring out how devices like this can be built and put to use.  Notice the cryptic language, unrelated links (usually .pt addresses) and text that looks like it was cut and pasted.  there will also usually be some black and red highlighted text (for no particular reason) in posts from lancaIV...
Bob Smith
Mags,
It does seem strange, compared to the usual Tesla-type setups, with the primary usually on the outside.
One thing I noticed, and I'm not sure...
- it looks like the upper secondary (over the primary) and the lower secondary are wound in opposite directions, but without seeing it from another angle, I can't be sure.  If that's the case, do we get the two oppositely wound coils essentially cancelling out each other's mag fields and putting out a lot voltage, like the series bifi coil?
If that's the case, then I'm assuming it would need to be stepped down to a useable level.
FWIW,
Bob
Tesluh
after studying that device closely (never saw a video of that actual one in use), the outer secondary is all wound the same way, Barker and Williamson RF coil 17 turns each half joined in the center.  Roughly 160 in long.  the primary inside wound opposite from the outside, roughly 6 wraps plus tails about 80 inches of wire roughly.  doing the same thing has produced some results for me in that the secondary shows activity when the primary is powered up.  waiting on capacitor bank and some other components but still don't have what I would call an exact schematic yet.  so many variations of this device and none of them I have seen convincingly doing what it has been claimed to do.
Tesluh
Just came across this written by "zilano"  in 2011
-To get overunity the input must be low(thin primary-high impedance) and secondary output(low
impedance) high amps. this is the magic behind dons circuits. but don never disclosed this magic
trick. people who saw dons designs made primary thick and secondary thin they had failures in
output power. underunity. or unity. i call this REVERSE TESLA COIL. MAKE primary as
secondary and secondary as primary. kapanadse got this idea and u can see his green box coil is
based on don circuit. see my attachment in one of my posts dons smith pdf dated 1994 bottom
circuit. the 6A coil 6 turns is same as dons circuit.
Sounds like I have my coils made backward and that the ones in dons photo would be wrong as well.  on a tesla coil the primary is thick and secondary is thin.  the difference between 10ga and 16 ga is about 4 times the cross sectional area.  the difference between 8 ga and 14 ga is about the same as well 4 times difference).  instead of 16 ga secondary and 10 ga primary I think I will try opposite, with 16 ga primary 4 times longer than secondary to keep same weight of copper in each.  Still not positive about the 2 pc secondary if the weight/length needs to be of the whole 2 pc section or each half.  this video is what I think my next coil arrangement is going to look like. https://www.youtube.com/watch?v=qBYdqSrJssU
Quote from: Tesluh on October 11, 2016, 10:22:54 AM
I am LancaIV,forum member Tesluh,and I am member since +/_ 2005 here and I did not changed my thinking and mention since this time !
I can deliver here copies from forum member posts which shows that we have been 2006 in this energy -overunity gain- device exploration stage and that not very many members remarked this !
Are you using an automatic translator ? I not ! I have learned English at school and clearly -I make
orthographical faults-from wrong defined orthografical definition view,because I use this language from ancient latin/portugueses + anglo/saxonic manner kind,something similar esperanto.
Did you never thought that the translator program(m)-s are seldom static,
these becomes updated/upgrated and probably with later wrong left-right and right-left thinking/writtings and logical content  translation,so no I but the translator program "worlks wrong" and let me seen by your eyes and feeling like a "saboteur/MIB or such synonyms" ,which are given to people or groups whose want to help and explorate good and sensitive science results,approved and probably Nobel-prize-awarded to the forum and members ( vulgo "VFolk").
Are you well educated,Tesluh ?
It can be that I am by my mother and family members,by teachers and many much more people and organizations up to the U.N.Organisation information archive content !
Tesluh,I am not a "MIB", but ------hmmmmmm, : ? and you ?! 8)  Klerus,NSA ?
Have a good time to find a fair and logical answer
        OCW  L(ancza)
p.s.: I am living in Portugal cause this you will find the "google.pt" suffix -you orthographical and geographical "greenhorn" !
Albert Einstein: "..... we,the humans,are only using -in average- 10% from our conscious potential
some less,Tesluh ::)   Do you know this New Age "Antheme/Hymn" https://www.youtube.com/watch?v=CNrnmDmffRc
and daydream/dreamtime explorer like here believed
https://www.youtube.com/watch?v=Gf1WT8VEZxk
             a buddhistic  ;D  from my side to you,member  :)
               as Abendland Wizar,Sinnbader ;)
