ENERGY AMPLIFICATION
0 Members and 40 Guests are viewing this topic.
Magluvin
Quote from: Dave45 on December 22, 2016, 06:44:42 AM
You have to use a flywheel circuit
Why the inductor in series with the diode??  In my experience, discharging an inductor into an inductor doesnt work well. The collapsing inductor will collapse so fast that the other inductor will impede the current rush.  This is if im seeing the circuit right...
Mags
leonelogb
QuoteWhy the inductor in series with the diode??  In my experience, discharging an inductor into an inductor doesnt work well. The collapsing inductor will collapse so fast that the other inductor will impede the current rush.  This is if im seeing the circuit right...
Mags
Dear Mags maybe we are missed something because Sr. Wattsup look Very happy with this circuit.
Dave45
What makes a coil ring if we only hit it one time with dc.
When the switch turns on the coil builds a neg biased field when the switch turns off the field collapses it brings in pos energy building a pos biased field.
A magnetic field can be pos biased or neg biased, if its pos biased it brings in neg energy if neg biased it brings in pos energy, a coil interacts with the environment if it didn't it would not ring at all.
Dave45
If you are using dc from a battery to pulse a coil you are supplying the electrons the ambient is supplying the protons.
If we had a primary that had absolutely zero self induction and a secondary with a high self induction then you can pump pos energy using dc.
Primary air core toroid- secondary ferrite toroid.
Dave45
To pull negative energy from the environment you have to use positive energy.
A flywheel type circuit must be used or you are just equalizing the charge on your battery faster.
Separate the pos and neg or they just cancel each other out in the environment. Give the field something to collect-tension circuit.
