ENERGY AMPLIFICATION
0 Members and 50 Guests are viewing this topic.
EMOD
what type of Energy Amplification?
shylo
Quote from: webby1 on February 04, 2017, 12:51:55 PM
I have long held the view that when I pass a PM past a conductor, that by itself, I only create a current flow, that flow being linked to the flux and on the rate of change of said flux,, not creating a voltage.
Does not the resistance of the circuit ,automatically create voltage?(E=IxR)
I see the counter force manifested by that current flow equaling the flux that is creating the flow and the force used to create the change,, moving the PM past the conductor.
Yes I agree , so have the formation of this counter force to augment the next stage of generation.
I read that the change in flux induces a voltage,, which is not what my view is.
You can't use a single coil or even two ,you need at least three fields, but you can use more, but always an odd number.
Just what I'm seeing.
artv
shylo
Sorry Webby, I did something wrong my questions somehow got entered into your post.
artv
forest
Quote from: seychelles on February 04, 2017, 12:58:44 PM
THE WAY I DECIPHER THIS DRAWING IS THAT THE WINDING ARE WOUND ORTHOGONALITY, AND THE SWITCHING ARRANGEMENT IS ACTUALLY A DC TO 60 HZ INVERTER , AS THE INPUT SOURCE..
Yes, primary winding is strange. You got it. :-)
Doug1
Quote from: Erfinder on February 04, 2017, 08:07:51 AM
This is where I set my compass and sail into the sunset.
Your opening line is where the triode part comes from...maybe....  ( a careful consideration followed by a careful comparison.)
Consider the vacuum tube is a valve used to control "electrical current", and the Vacuum Triode is/was a valve used to control "magnetic current", a switch for magnetic circuits.  Noteworthy, with the prior, the supply is extraterrestrial, whereas with the latter, the source is included...  Hope this inspires....
be weary of compasses you have to wind up.
