ENERGY AMPLIFICATION
0 Members and 46 Guests are viewing this topic.
sm0ky2
You have to understand how length and frequency are related
The wavelength and the physical length
Should be an exact multiple and divisor of one another
Take for instance a radio transmission antenna
Say you want to broadcast a signal at 103.3kHz
Your antenna would work best at 190.512 ft tall
There are other heights we can use but a full wavelength
Is 9525.6ft long
Taking 1/50th of this length, the signal becomes resonant
With the antenna. Radio stations also may use a 1/4, or 1/2
Wavelength
After a short time, an oscillatory signal will build up
The power levels can become so great that the entire antenna
Explodes!
That's a lesson we learned the hard way.
Now what we see at the base of the tower
Is an energy waster, also called a disruptor
It breaks the return resonant waveform to keep it from
Destroying everything
They consume a lot of electricity to run the energy waster
What we want to do is allow this effect to occur
Not disrupt it.
It happens naturally if all your lengths are right for the freq
You can fix your fudges by adjusting freq and adding impedance
sm0ky2
Quote from: forest on February 10, 2017, 12:13:58 PM
"Professor Wein has formulated a beautiful theory about it, which I understand has netted him the Nobel prize.  Wein's theories are admirable.  The only trouble is that he has overlooked one very important fact.  It is this: If the apparatus is properly designed and operated, there is no use for the quenched gap, for the oscillations are continuous anyway.  The radio men who came after me had the problem before them of making a bell sound, and they immersed it in mercury.  Now, you know mercury is heavy.  When they struck their bell, the mercury did not permit it to vibrate long because it took away all the energy.  I put my bell in a vacuum and make it vibrate for hours.  I have designed circuits in connection with an enterprise in 1898 for transmission of energy which, once started, would vibrate three years, and even after that the oscillations could still be detected.  Professor Wein's theory is very beautiful, but it really has no practical meaning.  It will become useless as soon as the inefficient apparatus of the day, with antennae that radiate energy rapidly, [are] replaced by a scientifically designed oscillator which does not give out energy except when it gets up to a tremendous electromagnetic momentum."
Nikola Tesla
Was he theorizing semiconductor technology way back then?
Jeg
Hi Erfinder ;)
Looks like to me that cap is a translation mean, for helping us to transform the high voltage emf response of motor coils, to current. As you have stated again, if current is what we need, then opposition to voltage is the right and only way. And this is a great advice helping us to see that even if the circuit forms a series resonant circuit, where we have to focus is not at the frequency domain, but at its behavior in time. Its transient response is what we are interested in. This alone, opens the door for a deliberating choice of cap value depending only on what levels of cemf we apply it. Thanks for your insistence! Hope I get it from the right angle.
wattsup
@endlessoceans
Go cry somewhere else. Your verbal jerking off is no better then what you accuse others of.
@all
Oh boy............  life can be so simple.
First off, I don't think @Erfinder will like that you are equating Colorado to the Ozone Patent besides the fact that yes it does involve damped wave.
Then let's just convene on one thing. If the working primary is in series with the coils of the fan motor which are of high inductance, in order to ensure a constant steady speed of the fan motor, hence a constant speed of the rotary switch, hence a constant steady operation of the ozone generation, the capacitor cannot discharge if the fan motor commutator brushes are connected. So this means the fan motor commutator must have brushes that do not overlap so there is an open fan motor moment while the rotary short switch is closed. Tesla uses the laminations in his fan motor design to store and keep the fan motor turning while there is no connection. He has even stated that in other similar motor patents. Just look at old photos of the device.
This is also important because the capacitor needs the inductance of the fan motor coils to charge quickly. Since the working primary has zero inductance, the capacitor must be matched to the inductance of the fan motor.
Now from there in terms of how this works, I will not interject because this is all relative to how you see the basic working of electricity and I will not confuse people here with my own take. But I will provide this one way of looking at the circuit in simplistic terms.
You basically have a dc battery supply. The negative goes to the fan motors coil 1 then through the fan motor brushes and commutator to fan motor coil 2, then through the working primary then to the negative side of a DC capacitor. The positive goes to the positive side of the dc capacitor where a wire from that same terminal leads to a rotary switch that shorts the positive between the fan motor coil 2 and the working primary.
So here is one question. When the rotary switch is open and the fan motor brushes are closed, define where the positive and the negative of the battery source reach to inside that series loop. @Erfi you need to think about that as well here because this will show how you see the function.
Then from there, when the fan motor brushes open and the rotary switch closes, define again what is the interplay between the battery source positive and negative and the capacitor discharge. Here again your opinion will be defined by what you see and know about electricity.
In any case, there is only one object to all these interplays and that is the most complete CHANGE in polarity and strength at the working primary. Whatever you try, if it does not produce the most complete change, the coupling from the working primary to the secondary will not be forceful enough to produce ozone. I use the word "change" to denote that an extreme bias/rebias is active here that can only occur if the working primary changes from a positive state to a negative state so it can then change back to a complete positive state and so on. Maybe this will tickle some of you to think about how our electricity works besides this notion that it "flows".
Also remember that capacitors discharge on connection and inductors discharge on disconnection and that both are used in this patent. Also Tesla never equated the word "field" with anything airborne, he does not use the term "field collapse", he does not use the term "electron". He was the most honest and unpretentious inventor of his times and the use of the word "field" can be equated to using the term "magnetic presence" or "magnetic influence" without defining it in terms of an "exterior presence" because he knew in all honesty that such was never confirmed nor can be.
@Erfi, I get it but maybe one day you will come around and see this from a purely objective stance, an honest stance where effects are described to the limits of their merit and not to the unlimits of our learned or indoctrinated imagination where there is this desperate need to be right at any cost.
wattsup
endlessoceans
Quote from: wattsup on February 11, 2017, 04:22:59 PM
@endlessoceans
@all
wattsup
Nawwww....poor baby.  Did it strike a little chord with you?  There there!!  I understand you must be upset that your beloved yellow buffoon Trump is not making America great again but that has nothing to do with energy.   LOL
