ENERGY AMPLIFICATION
0 Members and 188 Guests are viewing this topic.
forest
If you have an installation  CD with the same service pack then run from it and choose to repair system (not replace) , there is an option to press R to do this but it's a kind of tricky because this option is in somehow not clear place (to me) in installation menu - I always have problems to find it.
That would replace all system files with fresh ones from instalaltion CD.
Ooops, I missed that part you said that hdd drive is not visible to the installer.That's not good.Maybe some tool like fixmbr can help.
forest
Proposition of solving puzzle:
Take a water container with large amount of water in rather thin can to have big pressure on a hole in the bottom . In the hole mount a tube changing diameter from bigger to smaller . At the end of tube there should be very high pressure of waterjet. Make it work on turbine generating electric current and store in big capacitor or battery or allow to directly power efficient water pump with hose of much bigger diameter then the outlet from container. Of course there should be another container at the bottom to collect water.
Pump water from bottom container back to the top using this efficient pump.
Because outlet from upper container has short diameter water flow fast from it with high pressure but the amount of water depleted from container is small.
Tito ?
pese
Quote from: Tito L. Oracion on February 06, 2011, 06:34:57 PM
Hi sir pese good day!
This (pict you showed) will not work because you are not getting the whole weight of the water ok.
what i had said is that: How can we use the whole weight of the water.
This was only an JOKE
(i taked it from "overunity.de")
Also it was only for : "Nonsens"
BUT, think about this to find out an better way...
Quote from: forest on February 07, 2011, 03:16:55 AM
Tito ?
Water pressure due to gravity in an unsealed container depends.... guess what .... only on the depth of water at the measurement point. In other words, the size of the outlet tube doesn't matter as far as pressure is concerned. You will of course get more _flow rate_ at a given pressure from a larger diameter tube. Don't believe me? Then do some experiments for yourself.
This is a "gravity powered" system you are talking about. In other words, just like all gravity "powered" systems, you get out what you put in--- minus losses. Sure, use a "super efficient" pump to cycle the water back up to the top reservoir.... but no matter how clever you are in pumpmaking or stringing pipes, the falling water can only provide the same amount of energy as it took to get it up there in the first place by whatever method you choose.... minus losses.
Magluvin
Thanks for trying Forest.
I finally found a forum that describes my problem to a T. But their solution isnt working for me yet.  I tried the fixmbr, chkdsk, and a multitude of other things.
It appears that there are a lot of others with the problem.  I tried Nlite which copies the OS disk to a folder then you can add drivers and it embeds them into the folder software. The problem is the disk wont auto run/boot, even if I remove the hard drive from the boot list.  Im at lunch.  Tonight I will try to load the folder to a usb ram drive as those are acceptable to boot from.
Thanks for trying though. I like ya forest, you are good people. ;]
I hope I can get this going so I can get to fiddling. =]
I have a larger neon transformer pack to try the AV plug, as I think it will charge much faster using 1 wire. I have to order larger caps.  I was going to get some a while back, but things got in the way of getting that done. I like what they are finding with the Kapanadze thread.  But the claim of radiation steps me back a bit.
Its funny, Tesla was involved with so much power zapping all around him, yet he lived a long life.  Hopefully we come up with something safe.
The water deal, cant say if we will ever know what teets is thinking. I really just dont want to go through a lot of trouble  for nothing, again.  We cant keep jumping around to ever new ideas and never finish anything.  So far, we would have a better chance at winning in Vegas for the weekend.
Mags
