ENERGY AMPLIFICATION
0 Members and 256 Guests are viewing this topic.
sm0ky2
Quote from: leonelogb on February 14, 2017, 08:15:14 PM
@ll
What does mean those words.
Ozone Patent.
Quote:
"If air be forced between the plates P during this discharge, the effectiveness of the apparatus is increased and ozone is generated in large quantities"...
Could be, that him is talking about a Motor-generator, that increased its effectiveness with load. And the Next:..
"Continued production of ozone in unlimited amount".
I just asking!
That describes the action of the fan. And to prevent from repeating
Myself, I will direct you to my posts above where I talk about that.
sm0ky2
Quote from: Grumage on February 14, 2017, 01:36:51 PM
Dear sm0ky2.
I have to disagree.
A " Spark gap " suggests high voltage, in Tesla's patent it's plainly a rotary switch, connecting/disconnecting the series/parallel L/C tank circuits.
Cheers Graham.
You are disagreeing with Tesla, not me. But do as you please
sm0ky2
The low-voltage side of any Tesla oscillator
Is controlled by a spark gap.
They didn't have transistors back then.
There were vacuum tube diodes and triodes
Which Tesla did experiment with, but for the most part
He preferred to use a spark gap for precise control
Over the frequency.
The driver circuit for the Tesla coil is controlled in the same way
A spark jumps across the primary to excite the hv coil
They are all the same oscillator
Tesla references his oscillator patent IN the first paragraph
Of the Ozone patent.
If you look at that patent (#462418) you will find the
Following terminology:
"This generator I connect up with a condenser or conductor
of some capacity and discharge the accumulated electrical energy
disruptively through an air-space...."
Any questions?
jbignes5
 Now that you have gotten this lets look at the improvement Tesla did to the primary source.
  1:) This is the "to be" discharged into transformer.
  2:) The whole circuit.
  3:) the magnetic controlled variable interrupter
  4:) the effect of this kind of discharge after transformatio
Reference: http://tfcbooks.com/tesla/1892-02-03.htm
The first picture is a no core version. The form is a wooden dowel that is supported by additional structure in the oil bath wood case. Tesla said it should be shielded by metal but for his purposes of testing the extremes of this setup he didn't use it in lab.
The whole circuit is shown here in picture 2. The transformer is on the right after the magnetic variable spaced spark gap. This spark gap is a special beast. Sorta like a transistor but no power limits. The magnetic crossing filters the discharges or combs the plasma as it crosses the gap. This makes the electrode last longer on the transformer side of the gap. You could think of it as an infinite amount of division in the plasma after passing through the magnetic field flowing across the gap towards the discharge collector electrode. Instead of one massive conduction happening the conduction gets interrupted a vast amount of time. This causes the target electrode to get massive amount of hits in time instead of all at once discharge. You could think of it as a string of pearls flowing towards the target electrode. This would cause a minute variance in the current that once fed into a resonant system would build huge movements of current. In this case the current is being transformed into unbelievable voltages from an ordinary unit by the transformer and hence the need for an oil bath around that transformer. This is to keep it from producing OZONE and destroying the transformer coils.
The transformer should be designed with a bifilar coil in the primary discharge path. This is to allow the reduced cemf response to NOT interfere with the forward EMF of the discharge. Dumping high current low voltage discharges, low in the sense of 1v-2kv (Tesla was used to working with millions of volts so that was low to him, into a regular solenoid wouldn't work because of the self inductance of that solenoid. It has to be a Heavy Bifilar coil in order for this to work and a high voltage winding as the secondary to transform the discharge into a high voltage impulse.
You have to understand that this is leading into a plasma physics area and the movement of plasma around a high voltage source. This is just to learn how to attract the plasma to the system. Figuring out what to do with that higher density of plasma around this system is the key. What effects can a higher density of plasma around a magnetic device do? Does it make the effects of a magnetic system become enhanced like using an iron core does with magnetism?
We know that plasma has magnetic channeling properties. We have proven this already visually and experimentally in the lab. What effect would enhancing the plasma field around magnetic devices do? Would it magnify it's output? Could this high density plasma field be used as a fluid and used in the same methods to gain advantage?? Is this what Tesla was making impulses into? The medium of the density of plasma?
As a side note the magnetic filter across the gap has a singular direction or polarized flow. This one component could be responsible to making the discharges true impulses of one direction with no reversal of the gap. so this means one coil end will always be positive or negative in the output?
sm0ky2
"Air gap" inherently contains an impedance that does
Not exist in a direct contact commutator.
"What does it matter?"
Just about everything
