ENERGY AMPLIFICATION
0 Members and 36 Guests are viewing this topic.
Leely
Yeah, but you need to amplify first before using resonance. Resonance is a way of adding efficiency in other to reduce loses. Resonance on it's own, is not an amplifier, but it aids amplification, and it's normally used in lc circuits.
Magluvin
Ok. Just tried the av plug with 1n5399g diodes and a 22uf cap. Pic shows the combobulation using magnet rotor and reed to do the switching at the moment. Made a half bridge mosfet driver for the cheap square wave gens i had bought. Working on 2 other dr boards to use here.
The 22uf cap charges fast surprisingly. dont think Ive ever seen one charge that fast. Will do a vid tomorrow if I have time. just a quick spin of the wheel and it was over 200v. 100v cap. Need to make one with higher voltage caps.
Mags
Magluvin
Quote from: Leely on May 16, 2020, 10:37:09 PM
So then what is your version of how to amplify exactly?
Mags
Leely
Let me still clarify something that I know. Resonance works well with circuits that have secondary, or circuits that have what we call second coil. It only bridge loses between the primary and the secondary coils. So if you're putting 100% in your primary, with resonance, you can take 90 something percent from your secondary, than when you don't have resonance, depending on how you build the circuit. But a circuit  that amplifies could be added resonance to bring out it's best, if it needs it.
Magluvin
Tesla made a tapper device that shook a multi story building. So in his mind I believe he knew that the amount of energy that was stored in the buildings movement, once it was at say max of where he would not let it happen any further, that there was more energy happening in the shaking building than the total amount of energy it took to get that building shaking. Does that sound about right?
So I believe he knew that the energy of the vibrating building had more than enough energy to wind up the spring in the tapper box to do it all over again with most likely some energy left over. Is this not what he was trying to convey?
So thats my path. For some time now. Over the years I have had this on my mind and how might we be able to harness that. Most of the things you bring about by way of the use of LC circuits and resonance, has nothing to do with trying to work and look for a potential gain. Anyone that doesnt have OU or FE on their mind may never even give the idea a thought or even try because they have different goals for their use of these circuits in whatever they do.
One thing I found about a series connected bifi coil some time back is that it can be set into resonance by way of just 1 wire that has a changing voltage potential at the freq of the coils resonance. Doesnt even have to be high voltage. That little cheap square wave gen in the pic can get the bifi rolling 1 wire. You can take a cig lighter that has a quartz sparker instead of flint, remove it from the lighter, and just spark it into the air an inch or 2 away from the coil and it will ring fairly good from that impulse.
Now i am working the bifi as first a capacitor where the 2 bifi windings are not connected at all to each other, charge that capacitance, then short out the 2 bifi leads to then make it series connected(still open ended on the other ends of each winding) and she rings hard. Now Im using the third winding with only one end connected to the AV plug and that cap charges pretty darn fast with only one wire to the av plug and the other end of the winding is open!  Next is to put another av plug on the open end of that winding to charge 2 caps.  Im guessing that both caps will charge faster than when it was just 1 av plug. Can you imagine why I might think that? ??? I think that because I believe I know how and why the av plug works in these configurations, and knowing that should give the answer as to why 2, one av plug on each end of the winding, may charge faster than one connected like I said above. ;)
Below is the circuit of what I had shown above on the bench. The diode on the blue heat sink(unnecessary in this circuit, just happened to be on the diode) in the diagram is correct but not in the pic above as shown.  The diode just kept things going in one direction with long periods of switch off time while I was trying things using the reed sw and the rotor. Once the switching circuits are fin for this, there will be no time for reversals of current between switching times as the large inductor will be conducting forward at all times as the time will be very short in comparison. The circuit in Sim below doesnt actually work as the app doesnt recognize bifi, trifi coil conditions and functions. It is just for your benefit to see the circuit. The 3 inductors signify the trifi coil and how it is connected.
I think it is interesting stuff. ;D ;)
mags
