Tesla Patent 382282, and all related to his transformers/converters
Started by clone477, February 07, 2009, 04:31:11 PM
Room3327
Well after reading it thoroughly, I'm not exactly sure what point he was making. I don't know if it helps or not. The idea of high speed (RPM) causing high voltage, that came up, is really what I was focusing on.  The idea that high voltage and low current are more efficient when generating power, well that's a new one on me, but it may be of some help.
Room3327
Here's my build of the 2 phase drive circuit.  It works as designed and puts out about 9 volts RMS into a 8 ohm load on each phase.
It appears to have minimal distortion and will output about 500 ma at 500 Hz, and at 10KHz it outputs about 120 ma.
Tito L. Oracion
Quote from: Room3327 on March 13, 2009, 01:06:25 AM
In transmitting power to a long distance, i had read that it start from source not so very low voltage but to transmitt it efficiently they have to transform  it first to a very high voltage then back to low voltage again which is ready to consume by houses.
i think and i believe that a tpu also work this way  8)
SOME KIND OF A TESLA TRANSMISSION THING
God bless
otits
Room3327
@All,
     I have been running this device for several days now and it runs nicely on the circuit I designed for it.  I must report that I find nothing other then transformer action with it regardless of frequency or power input and I can vary both.  BUT I have found a major mistake that I made in the design of the transformer.  I built from Tesla patent # 381970, and the hookup of the field coils shown is wrong.  When operating this device it did not seem to have a rotating field that I could find in any manner.  I went back to the last patent of Tesla's on this # 390721, and realized he had changed the connections to the field windings. Connected as he shows in 390721, I can now see how a North-South magnetic pole forms and rotates about the device. Connected the way I have it the field just moves back and forth similar to transformer action and that's all I am seeing.  Unfortunately I built my converter so neatly, I soldered and heat shrunk all internal connections on the field coils, I can't get at them to change the configuration without tearing it all apart.  Now I know the major difference in the patents, I wondered why he patented it several times.  I will have to wind another transformer and try again, this time I will bring all 8 field wires out of it.  Getting more out then you put in is damn hard to do or we would already be doing it. Good luck to everyone else working on it out there.
