Possible unconventional overunity motor/generator?
Started by gravityblock, February 12, 2009, 07:20:05 PM
gravityblock
Possible Overunity Motor/Generator
1) Iron core.
2) 2 seperate wires.
3) Wrap first layer of wire around iron core as we normally do for a motor/generator.
4) Wrap second layer with the second wire perpindicular to the first layer.
5) Repeat step 3 and then step 4 until coil is finished.
6a) Mount magnets to the stationary stator with a rotating coil.
6b) Or mount magnets to a rotating stator with a stationary coil.
6c) Or mount magnets to rotating stator and a rotating coil.
You will have 2 positive wires and 2 negative wires. One set of wires will be leading to a conventional generator (or possibly to an unconventional generator as described above) and the other set of wires will be leading to a motor (or possibly to an unconventional motor as described above).
Will one of the combinations of conventional to unconventional motors or unconventional motors to unconventional motors provide overunity? Which setup would provide the best opportunity for overunity, if any at all?
gravityblock
jadaro2600
Billy Witch Doctor says: "You say funny thing!"
...you're probably right though - I'm usually wrong however.
Dave45
Quote from: brian334 on February 12, 2009, 07:30:28 PM
Thank God for drugs.
have you tried it , I know its against such and such law, but have you tried it.
The math doesnt add up, but  have you tried it.
I didnt think so
